Old 05-29-2011, 07:44 PM
crazyhorse crazyhorse is offline
Default Simultaneous AES/ADAT/SPDIF on HD I/O Digital
Does anybody know whether the new AVID HD I/O 16x16 digital interface allows you to use different digital formats at the same time? I am guessing that you can have ONE OF 16 AES, TDIF, or ADAT, but the interface also has another digital I/O section on the base machine that provides an additional 2 spdif or 8 adat. Thus, I am guessing that you could, for example, use the 16 AES plus either of the 2 spdif or 8 adat - ie. you can run different digital formats across the two "cards", but can only use one format within each card. So in effect you can have as many as 24 digital I/O working simultaneously (eg. 16 AES plus 8 Adat; or 16 adat and 2 spdif)
I read the consolidated HD I/O guide on the avid site and it was somewhat confusing since it covers all three I/O versions at the same time.
Thanks.
Old 05-30-2011, 02:22 AM
Bill Denton Bill Denton is offline
Default Re: Simultaneous AES/ADAT/SPDIF on HD I/O Digital
Not only was the manual confusing, the email I got from Avid regarding this question wasn't much clearer...
From what I've been able to suss out, here's what it is...
You can only have 16 inputs and 16 outputs at a time.
These 16 inputs/outputs can be any combination of those on the input/output cards installed and the input/outputs built in to the "enclosure".
In other words, you can use any combination of the inputs/outputs on your unit, but only 16 inputs/outputs.
Again, this is just my understanding, but it is based on fairly decent information.
Now, if I can manage to explain it in a simple fashion why can't Avid?
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 05-30-2011, 04:37 AM
the dude's Avatar
the dude the dude is offline
digital outputs are all mirrored to the AES/TDIF/ADAT on the digital IO card
only the (ENC) outputs can be independent but again only one format is available
16 outs MAX !!!! but you can use use all outputs of AES/TDIF/ADAT simultaiuosly but all are mirrored AES chan 1, TDIF chan 1, and ADAT chan 1 will only output the same signal
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 05-30-2011, 08:33 PM
Thanks guys. That is helpful. And it is actually good news for me, as the ability to mix i/o is more important that the total number of channels. cheers.
Old 11-18-2018, 02:24 AM
Firechild Firechild is offline
I would like to rephrase slightly...can you you use both AES/EBU enclosue and S/PDIF enclosure out simultaneously with the same signal, Pro Tools master Output? What is confusing is in the Hardware setup you have to choose Digital Format AES/EBU or S/PDIF (or Optical (S/SPDIF)?
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 11-18-2018, 08:18 AM
BScout BScout is offline
Yes. You set to “digital output” and all outputs on the enclosure send parallel signals. The format is about the inputs (or in the case of optical s/pdif, to use that instead of adat standards)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
003 ADAT Optical & SPDIF inputs - simultaneous recording? ciacco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 03-28-2007 07:49 PM
Digital mixer pre's or 002R? SPDIF or ADAT I/O? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-14-2006 08:24 PM
possible simultaneous ADAT with 192 & 192 digital? Judson Pro Tools TDM Systems (Mac) 1 07-03-2004 02:41 PM
digital ins SPDIF and ADAT simultaneous locosoundman Tips & Tricks 2 04-25-2004 06:08 PM
ADAT to 4 SPDIF i/o's & digital inserts polchik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-18-2003 01:53 PM
