Old 05-21-2018, 06:49 AM
Tsen Ru Tsen Ru is offline
Default Gradual fade across multiple clips
I have four adjacent clips on a track. Each clip is cross faded with the next. I am looking for a way to easily apply a gradual fade out across the entire 4-clip section.
I have tried to "group" the clips to create a single track to fade out, but pro tools says i cannot group clips with cross fades. I also looked at the batch fade tool, and was unable to locate the appropriate function.
PT12.1
Old 05-21-2018, 11:51 AM
BScout BScout is offline
Default Re: Gradual fade across multiple clips
A) consolidate the clips (with crossfades) into a new clip. Then use the new file and apply your fade
or
B) use volume automation for what it was intended
You can't apply fades/crossfades to other fades/crossfades. There is no "workaround"
Old 05-21-2018, 05:52 PM
My 2 cents, since consolidating the clips will make the cross-fades permanent, I would leave them alone and use BScout's option of volume automation. Just show Volume, drop 2 breakpoints and drag the end down to nothing. It took longer for me to type this than it will to do it
If you do choose the consolidate option, duplicate the playlist first
Old 05-22-2018, 06:31 AM
Thanks for this
Old 09-22-2018, 11:18 PM
inf0l inf0l is offline
You can also create a Region/Clip Group and apply a fade on the grouped clips.
That said, this is what volume automation is for...
Fade OUT to multiple clips one single track? mgmartino Pro Tools 12 8 09-29-2017 08:22 AM
Fade Out Multiple Adjoining Clips tangoportland Tips & Tricks 8 12-03-2015 03:04 PM
Gradual EQ Fade Effect Samwell macOS 5 01-03-2015 11:48 AM
fade in multiple using fade handle maufau Pro Tools TDM Systems (Mac) 5 09-27-2014 02:01 PM
Fade-In and Fade-Out on Multiple Disjoint Regions holden Pro Tools TDM Systems (Mac) 2 11-30-2007 01:22 PM
