Old 01-15-2009, 12:42 PM
Dboy Dboy is offline
Default Mac G4 and PT 7.4.2 Leapord Good Idea?
I have an older Mac G4 MDD FW800 computer and PT 7.4. I've held off as long as I can , but now need to upgrade to Leopord (OSX 10.5) and 7.4.2. The compatibility chart shows "untested". Anyone have any experience with this combination?
Old 01-17-2009, 12:17 AM
JChance JChance is offline
Default Re: Mac G4 and PT 7.4.2 Leapord Good Idea?
Ok, here's the deal-
It will work... *but*-
You are probably going to be limited to basic tracking & editing. Don't expect to be able to mix using any significant amount of plugins. For that matter, don't expect to be able to use very many virtual instruments as well.
I've got a G4 MDD tower that I just bought as a second/backup/family computer for next to nothing. I had some extra drives & RAM laying around, so I maxed it out & got it running as fast as is possible for the machine.
With Leopard 10.5.5 and PT M-Powered 7.4.2, I'm able to open decent sized sessions that were cut on HD.... But in order to not choke the computer, a lot of the heavier plugins & VI's are inactive.
Useable, yes... But will it run like an Intel machine? Not hardly.
You just have to determine what your uses are. For me, I'm a guitar player that does a bulk of my "at home" Pro Tools work simply adding overdubs to existing projects. It works fine for adding a couple of mic'ed amp tracks & forediting work.
But if I were an engineer (which I'm not) doing any type of real mixing, I don't think it would work very well.
Good luck-
Good Idea/ Bad Idea Slade General Discussion 0 07-24-2003 07:30 PM
onboard sound, good idea/bad idea?! sampb7 Digidesign Hardware & Software 1 02-22-2003 02:44 AM
HUI still good idea or should i use a da7? David Fisher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-01-2002 04:42 PM
is this a good idea ? tom_mac Pro Tools TDM Systems (Mac) 7 04-12-2002 08:31 AM
is this a good idea whosmatt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 09-08-2001 09:16 AM
