Old 07-28-2006, 11:15 AM
jah-d jah-d is offline
Default QT time code won\'t match to PT time code in PT LE
I brought a project from my office to my home system. The project's QT movie and PT were on sync at my office. However if I opened the same project at my home system, QT time code and PT time code won't match each other. The QT movie is 6flames earler at home. I can't figure out reason of this. Do you guys have any suggestions to solve this problem?
Thanks.
Work System G4,PT6.4, MIX,DC30
Home System G5, PT LE 7.1 , DV toolkit 2, Using secound video out to preview the video
Old 07-28-2006, 11:32 AM
latvia latvia is offline
Default Re: QT time code won\'t match to PT time code in PT
I would check quicktime movie offset setting first. Although, since the difference is 6 frames, it is probably not because of the offset, but check it just to make sure.
Then, maybe something got messed up in the session setup when you changed systems. This may sound stupid, but check if timecode rate is the same as it is on your work system.
What timecode rate is it? If it is 23.976, maybe the problem is in your work system. I don't remember seeing this rate in 6.4... maybe I'm wrong. Just a thought.
http://www.andrewuvarov.com
Old 07-28-2006, 01:47 PM
georgia georgia is offline
did yoo open a copy of the session or a new session? If you opened a new session check the start time of the session and match it to the First frame of the QT. Make sure that the QT doesn't have multiple frames at the head of the file with identical timecoede numbers. ( happens sometimes if it was captured from tape ).. Also make sure the frame rate is the same for the session and the QT files.
cheers
geo
georgia hilton CAS MPSE MPE
Hilton Media Management
Film Doctors http://www.filmdoctors.com
Me... http://georgiahilton.webs.com/
Stage 32 http://www.stage32.com/profile/6569/georgia-hilton
My Production Company http://www.hiltonmm.com
CREDITS (partial) http://www.imdb.com/name/nm0385255/resume
MEMBER: IATSE LOCAL 700
Old 07-28-2006, 02:53 PM
Default Re: QT time code won\'t match to PT time code in PT LE
Thank you guys for advise. This project is a copy from MIX 6.4 System. Time code rate is 23.976.QT movie flame rate is 23.98.
I checked offset as well. Also I don't see duplicate flames at the begining of movie. It's very strange.
Old 07-28-2006, 10:44 PM
Charles D. Ballard Charles D. Ballard is offline
Mix 6.4 systems won't do 23.976 fps. The option is there, but the hardware won't do it. Perhaps that's the problem.
-Charles D. Ballard, M.P.S.E.
"I bent my wookie"
HTML code is On
Are WE ever going to get Time Code? Tao Jones Pro Tools M-Powered (Mac) 1 10-27-2009 03:00 AM
Moving Start time and time code with it... KungFuLio Pro Tools TDM Systems (Mac) 15 08-05-2009 08:42 AM
couldn't lock to Time Code in time for vid record benderbro Post - Surround - Video 3 12-28-2004 11:21 AM
time code swamix General Discussion 1 11-05-2003 03:48 AM
Time code not available iank Pro Tools TDM Systems (Mac) 4 08-09-2000 08:06 PM
