Does Eucon limit ethernet?
I am considering getting an iConnectivity MioXL and it uses Ethernet for midi. Will I be able to use it with the same ethernet hub that my Dock and S1 are connected to? Also for future reference, is there anything that I cannot use with the same ethernet hub connected to my Dock and S1? In other words, does the Dock and S1 restrict further use of a single ethernet port? Can AVB and Eucon share a hub or would I need to use another ethernet port on my laptop?
Re: Does Eucon limit ethernet?
This should be OK to use on the same network. Where problems start is when trying to use Audio over Ethernet protocols and these can hog all the bandwidth.
Got it! Thank you so much!
C24 on Ethernet pcie not motherboard Ethernet? | mfefc | ICON & C|24 | 0 | 01-01-2021 10:21 PM |
EuCON/Ethernet Connection Question | ViciousLullabyz | Avid S1, S3, Dock and Control App | 3 | 05-08-2020 02:52 PM |
How to run EuCon over Ethernet while accessingInternet over Wifi? | opiante | Artist Series | 9 | 12-17-2017 10:18 PM |
Does Eucon actually work with a usb/ethernet adaptor? | robertg | Artist Series | 1 | 07-23-2015 11:36 PM |
d-Command and MC Transport / You cannot use EUCON with other Ethernet controllers | wouters | Artist Series | 2 | 04-17-2014 01:28 PM |
