Bounce to quicktime: audio gradually misaligns
Just started my first film score in Pro Tools HD today. Worked on one scene, about 5 minutes and did a bounce to quicktime. Upon viewing in quicktime (through core audio) I noticed the audio was inline at the top of the piece but by the end was off by around 1 second. And this is based upon my score plus the dialog that came with the video. Here are the specs:
DV Stream NTSC, 48k session, PT 7.3.1, OS 10.4.11, Digi 192. I also was running video out firewire (manually offset video to adjust) but even if this was the problem, the issue would be consistent, not continually worsening with time. Thoughts? |
Re: Bounce to quicktime: audio gradually misaligns
`My name is Pro Tools HD, King of Kings: Look on my works, ye mighty, and despair!' Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare, The lone and native DAWs stretch far away. |
Thanks, i'll double check the session. But, if the frame rate was off in PT, wouldn't the preview playback in PT be out of sync as well? Right now, everything syncs perfectly within PT but the issue pops up when the video is exported.
I am able to BTQT in 7.3.1cs7 in OS 10.4.11 on a Mac Pro HD|2 no problem. Things to look out for:
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
I was working with a 32khz dv file. Pulled that into my 48k PT session; could that be a problem? Or are you just talking about avoiding SRC when coming back out of PT at bounce time?
Also, i was using markers to set my start and stop boundaries. then end marker was for sure past the end of the video file. I'll have to go try bouncing just the length of the video... thanks |
Let us know if you get it to work or not.
Will do, thanks!
Awesome, bounced within the QT region, kept the sample rate and use no pull up/down and it's all good. It makes sense now that I think about it. I noticed, when playing past the QT region in PT remains displayed. But, it only bounce the length of the region so afterward it must have stretched the video out to match the audio length... Anyway, thanks for the help
Glad you found the solution and it was that easy.
Bounce to Quicktime movies have no playback audio on 003 | neilshah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-25-2008 03:26 PM |
Bounce to Quicktime with 5.1 audio? | potatohead | Post - Surround - Video | 2 | 10-31-2007 10:51 AM |
Quicktime bounce plays audio, but no video! | crizdee | Pro Tools TDM Systems (Mac) | 2 | 04-20-2007 04:34 AM |
Bounce To Quicktime Only Outputs Audio | Willard | Pro Tools TDM Systems (Mac) | 17 | 08-29-2005 06:27 PM |
Bounce to Quicktime Movie Creates Only AUDIO ?! | DMK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-11-2005 02:56 AM |
