Old 02-23-2011, 12:45 PM
legasafe legasafe is offline
Default MXF Workflow Help!
Hi all,
At my previous place our workflow would be to bump up any client supplied QTs to tape and then ingest into Pro Tools as MXF.
I'm now running somewhat off of my own back and as such don't have access to digibeta decks or the like. I figure there must be a tapeless workflow for this scenario, however I'm quite lost at the moment. I understand that an MXF is simply a wrapper for certain codecs, I've tried using episode pro to convert received QTs into all different codec flavours from IMX to DVPal and still can't get anything to agree with Pro Tools.
What exactly does Pro Tools want to see so it can work swimmingly and scrub tightly with my Mojo hardware? I've toyed with the idea of getting an Avid MC in, I gather that would be able to export the files I need with minimal hassle? I am however intrigued as to if there are any other possibilities...
If anyone has suggestions as to a workflow for creating these sorts of files, or in face anything I could do to improve my life at the moment it would be much, MUCH appreciated!
Old 02-24-2011, 05:20 AM
Postman Postman is offline
Default Re: MXF Workflow Help!
Yes. I assume you are using Pro Tools HD and want to use an "Avid" movie track through MOJO, not a "QuickTime" movie track through MOJO. Your question comes up regularly here. You need either a Media Composer (can be an old version), Avid Express Pro, or Media Station PT to import/convert QuickTimes into Avid-centric media. PT looks for an Avid signature in the media, or its own signature (like when you captured off tape). If it finds one and the wrapped codec is supported by Pro Tools+MOJO, the movie is placed on an "Avid" movie track and works perfectly.
Many QuickTime movies can be played through MOJO (Video out Firewire), but accuracy and smoothness are usually compromised.
Old 02-25-2011, 06:40 AM
Hmm I had dreaded as much. Thanks for your time!
HTML code is On
Workflow: Creating Film score music (template/setup/workflow) jhonny.eriksson Tips & Tricks 5 03-03-2015 10:08 AM
Workflow pinnacle Pro Tools 10 6 06-22-2012 10:01 PM
3D Workflow weso33 Post - Surround - Video 5 04-14-2011 06:43 AM
Workflow! kje Tips & Tricks 11 06-26-2010 08:15 PM
workflow sjon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-18-2004 09:43 AM
