002r midi input
Hey! For some reason I can't get any midi data into reason adapted since I installed the C/8. I can if I use the midi in's on the C/8 but not on the 002r. I used to have my Edirol pcr 50 pluged into my 002r. But now I can see the midi led on the 002r flashing and recieveing data but no reaction in PT or reason adapted. I moved the cable to the C/8 and changed the input under preferences in reason to C/8 and voila. What happend? Did I loose the inputs on my 002r?
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
Re: 002r midi input
Same thing here, instead I use an MPC, the MIDI outputs of the Digi002Rack doesn't work.
OUT! |
Re: 002r midi input
What's up with that? I wonder if someone (digi) could verify that if that's how it works. If so that sucks. I didn't read anything about that in the docs. Hmmmm.
Re: 002r midi input
My midi connections work as they please on my 002r. Sometimes my motor mix works fine, other times it is not detected.
002R MIDI Lights show input, but not in PT | groove guru | MIDI | 7 | 11-10-2012 07:15 PM |
New to MIDI. Input is quantizing. Input Quantize is disabled | LiamSlack | MIDI | 0 | 03-25-2008 08:59 PM |
002R input too hot | thereveilleroot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-29-2007 05:34 AM |
002R Midi input/output not shown as options | SumOdRsn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-07-2006 12:03 PM |
002R audio input | coyotehill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-03-2003 06:45 PM |
