Old 04-05-2008, 09:11 AM
DimitrisG DimitrisG is offline
Default Firewire 1814 is not working again
hello!!
I have an m-audio firewire 1814 audio interface and my pc suddenly stopped recognising it!
I already have changed the firewire card on my pc in order to be compatible with pro tools and it worked just fine for some time.. Has anyone any idea pls? I have even got the latest firmware for the audio interface but nothing changed. What should I do???
Thanx in advance
Old 04-06-2008, 08:47 AM
fizzler fizzler is offline
Default Re: Firewire 1814 is not working again
did you try to connect it on both FW-ports of the 1814?
Mac Pro 2.66 Ghz 4-core "Nehalem", 6GB
OS X 10.6.4
Metric Halo ULN-2, UAD-2 Duo
Pro Tools 9, Logic Pro 9, Live 8, Cubase 5
Old 04-07-2008, 05:51 AM
Yes, this was the first thing i've tried. I did all the usual "tricks" to get it working but there was no improvement...
Old 04-07-2008, 05:52 AM
Old 04-07-2008, 08:40 AM
DigiTechSupt's Avatar
Have you done an uninstall and reinstall of the driver software?
If not, I would start there.
If that doesn't work, can you give us a more detailed explanation - is it not being recognized by Pro Tools? Is it no longer in the Device Manager?
Avid Audio Tech Support
Support FAQ
Old 10-31-2008, 11:07 AM
The audio interface behaves eratically. I've reinstalled the drivers and even pro tools lots of times. It just stops working for a few minutes or hours when it suddenly appears to work completely properly and being recognized by PT. This happens all over again & again. When it works it is seen in the Device Manager. I use Pro Tools M-Powered v7.1.
Desktop
Mainboard : FUJITSU SIEMENS D2156-A1
Chipset : Intel i945G/GZ
Processor: Intel Pentium 4 640 @ 3200 MHz
Psysical Memory : 1024 MB (2 x 512 DDR2-SDRAM )
Bios : FUJITSU SIEMENS // Phoenix Technologies Ltd.
Bus Firewire : VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
Version : 1.10
Speed : 400 MHz
Video Card : NVIDIA GeForce 6200 TurboCache(TM)
Hard Disk : SAMSUNG (151 GB)
Peripheral Type : ATA
Model : SAMSUNG HD160JJ
Hard Disk : WDC (150 GB)
Model : WDC WD1500AHFD-00RAR5
DVD-Rom Drive : HL-DT-ST DVDRRW GSA-4164B
DVD-Rom Drive: TSSTcorp CD/DVDW SH-S183A
Monitor Type : ViewSonic VE710 Series - 17 inches
Network Card : Broadcom Corp BCM5750A1 NetXtreme Gigabit Ethernet Network Card : Broadcom Corp BCM4309 802.11a/b/g
Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3
Old 10-31-2008, 11:23 AM
That may be the problem - VIA firewire controllers are known to be problematic.
Unfortunately you didn't post an entire Sandra report, so I can't see which processor chipset you have. There may be an incompatibility there as well - can you repost an entire Sandra report, so we can see if that may be the case?
Support FAQ
Old 10-31-2008, 11:56 AM
What exactly is a sandra report? I don't think it is a compatibility problem with the firewire card because when I moved the firewire 1814 and the firewire bus on an another computer they both worked just fine. I should underline that for almost a year and a half the audio card worked perfectly on my computer.
I hope all the information you need is below...
General Information :
NorthBridge : Intel i945G/GZ
SouthBridge : 82801GB/GR (ICH7 Family) LPC Interface Controller
NorthBridge Information :
Architecture : Direct Media Interface (DMI)
Manufacturer : Intel (Fujitsu Siemens Computers)
Codename : Lakeport
Revision : A2
Bus Speed : 199.5 MHz
FSB Frequency : 798.1 MHz (QDR)
FSB max. Support : 800 MHz
RAM max. Support : DDR2 (667 MHz)
Memory Information :
Type : DDR2-SDRAM PC2-4300
Frequency : 266 MHz
DRAM/FSB Ratio : 4/3
Supported Channels : Dual (128-bit)
Activated Channels : Dual
ECC Diagnostic : No
CAS Latency (tCL) : 4 clocks
RAS to CAS (tRCD) : 4 clocks
RAS Precharge (tRP) : 4 clocks
Old 11-01-2008, 12:13 PM
Please if anyone has any ideas let me know. I am in a dead end for months now!!! Is it really possible that some firewire 1814 ended up defective after some time? I surely hope not...
Old 11-01-2008, 06:23 PM
Q-san Q-san is offline
HI,try 1814 to another friend(s) pc's just for test..
PT 10 not working with Firewire 1814 and CPU Error Messages Dirty Dead Pro Tools 10 6 05-21-2013 07:18 AM
No other way than the Firewire 1814? shultzee13 Pro Tools M-Powered (Win) 4 08-12-2008 12:54 PM
Mac Pro 2.66, Firewire 1814, 10.4.7 Imagine Pro Tools M-Powered (Mac) 7 09-21-2006 10:13 AM
firewire 1814 just stopped working!! donnieb Pro Tools M-Powered (Win) 3 03-29-2006 11:18 PM
firewire 1814 just stopped working!! donnieb Pro Tools M-Powered (Win) 0 03-27-2006 12:37 PM
