Old 07-07-2009, 11:10 AM
Chief Pronto Chief Pronto is offline
Default volume automation and a control surface (BCF2000)
When you're mixing tracks without volume automation, if you adjust the fader up or down, it brings the volume of the whole track up or down by the amount that you move the fader. but, once you have volume automation on the track, if you try using the fader, it just snaps back to the volume set by the automation. this means that once i have a single node of automation on the track, the faders on my control surface become useless since they're not touch sensitive.
is there a way to have the faders adjust the volume of the whole track while maintaining the automation? that is, if i have automation, and then lower the fader say 2db, that lowers the volume of the entire track, automation and all, by 2db?
thanks.
Old 07-07-2009, 11:38 AM
rhythmtechnologies rhythmtechnologies is offline
Default Re: volume automation and a control surface (BCF2000)
as the volume automation is tied to the fader what you're suggesting is impossible unless you (A) set up an aux and route the track into it OR (B) use an automated gain plugin instead of volume automation.
Old 07-07-2009, 12:27 PM
Murt Murt is offline
thanks.
Only HD has this option with 'trim mode' - don't think it's an option with one of the toolkits.
Have you tried highlighting the track in the edit window in 'volume' mode and just drag the already written automation down 2db? I think I might have done this before, just can't remember.
MBox2Pro / LE 8.0.5
Old 07-07-2009, 02:32 PM
yeah, this of course works... i just wanted to get away from the mouse if possible.
Old 07-07-2009, 05:49 PM
tha]-[acksaw tha]-[acksaw is offline
I write automation as my very final step when mixing, but sometime I do automate stuff for a rough mixdown or comp reference. I don't use a surface, so if you are trying to find a way to get the fader on your surface to take everything up or down by 2 dB after you write automation, your screwed.
But if you just want to adjust the volume after the fader has automation, I just add a Trim plugin to my track and do all my minor extra adjustments that way. It might seem like a pain to have to open a plugin every time you want to adjust volume, but its not that big of a deal to me. I just got used to it.
Like I said, I usually don't have this problem until I'm at the end of my mixing and usually my mix is static enough by then that I don't have to do much. Maybe a 1dB one way or another, but mostly my mix will just need automation at that point. Everything else is sitting nice.
If you really need the fader on your surface, i think rhythmtechnologies had it right. Just bus it into an aux track, and then control the fader of the aux instead.
www.TheSoundCoop.com
www.youtube.com/TheSoundCoop
PCAudioLabs 2.5GHz Quad-Core Q8300 FSB:1333/1066MHz, NB:IntelG33, SB:Intel ICH9DH/WinXP Pro SP3 / SATA HD's = 160GB(7200/8), 320GB (7200/16) x 2,500GB (7200/32) / 4GB DDR2-800 / FW = TI ChipSet / Gear: Apogee Rosetta800, ADL600, Avalon2022 // M-Audio = Profire Lightbridge, Octane 8's, BX5's BX8's & SBX // ProTools MP 8.0.5 w/ MPTK 2 - Velvet Waves Sonnox IK NI FXpansion Massy -- DVerb2.0 Test = 230 verbs
Old 07-08-2009, 12:34 AM
pianosound pianosound is offline
+1 ,,,,,,,,,,, also a great way, of coarse, to control a group.....
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Will a Behringer BCF2000 work to write volume and plug in automation with PT? rockguitarist1255 Pro Tools 10 4 02-02-2013 10:43 AM
Help With my Control Surface! BCF2000 with PTLE 8 Alexrkstr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-04-2009 05:42 AM
Adjusting volume during Bounce with Control Surface Brad Gillie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2008 01:15 PM
Can't write trim automation from control surface crizdee Pro Tools TDM Systems (Mac) 1 10-26-2006 10:28 PM
Uses for Behringer BCF2000 control surface in PTLE Tubthumper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-17-2005 04:21 PM
