Old 10-18-2007, 07:53 AM
teacherman teacherman is offline
Default Are the Soft Keys on the D-Command user-definable??
Was wondering if the Soft Keys under the menu "Func 1" "Func 2" "Func 3" are user-defineable.
I noticed there was an un-assigned button under "Func 1" that I'd like to assign as the "Delete" Key.
Although the "CUT" key is assigned, it doesn't seem to act the same as the Delete key.
For instance--removing unwanted automation-- after highlighting the portion of the automation to removed, the CUT key under the soft menu doesn't remove the automation but the Delete key on the keyboard does.
Thanks.
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 10-18-2007, 10:37 AM
Drew Mazurek's Avatar
Default Re: Are the Soft Keys on the D-Command user-definable??
They don't appear to be. I looked in the manual and tried a bunch of different key combos but nothing happened.
www.drewmazurek.com
Tips for moving custom user sets/soft keys to a new computer? mrsquid Artist Series 1 04-04-2013 02:37 PM
Assign Pause & key command to soft keys? mikekiraly1 Artist Series 2 02-03-2012 10:29 AM
D-Command Soft Keys Deleting Themselves MixMonster ICON & C|24 1 10-29-2011 03:27 AM
User definable documentation in the Help Menu sunburst79 General Discussion 5 03-21-2009 10:09 AM
Tab to Transient--user-Definable Threshold teacherman Pro Tools TDM Systems (Mac) 2 11-12-2007 04:42 PM
