Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 07-08-2015, 07:34 AM
Tim R. Tim R. is offline
Default "Select by Touch" blocks automation writing
Whenever I have "Select By Touch" turned on in the Eucontrol settings I only get an initial "touch" of automation (one break point) when I grab an S3 fader (initially). Once track is "Selected" all automation works fine (writes when touched). If I move to another (non-selected) track I get the initial single break point only until I "re-touch" the selected track to write. This is current Eucontrol version 3.2.2 and surface firmware has been updated.
Tim Reisig
System 1: Pro Tools Ultimate 2019.12.0, HD Native TB, HD OMNI, S3/Artist Transport/Eucon, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 07-10-2015, 07:07 AM
Default Re: "Select by Touch" blocks automation writing
Anyone else able to confirm or deny this bug?
Tim Reisig
Old 07-10-2015, 09:05 AM
ha2dorff ha2dorff is offline
"Select by Touch" means that the track is selected and activated. When you're in automation mode, every touch is written. But if you touch a fader without moving it, one value only is written. If you move the fader, values are written for every move when you are in play mode.
Maybe that's not your question?
Old 07-10-2015, 10:08 AM
Thanks for the reply, but you are missing my issue. When "Select By touch" is turned on, and I grab a fader (that is NOT currently selected) to write automation (Channel is in "Touch" automation mode), only one break point is written. Any other moves I make with the fader are ignored. UNTIL I release and RE-touch the (now selected) fader. THEN it writes all fader moves that I make. If "Select by Touch" is turned off all faders write all automation whenever touched (as they should).
Tim Reisig
Old 07-10-2015, 11:40 AM
Ups, sorry... Understand now :)
I should gladly have tested right away, but I'm on vacation. I'll test when I'm back in my studio (if no one else have done it before).
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 09:14 AM
is there "delay compensation" for writing automation via faders?? anotherchrisperry Artist Series 19 10-01-2012 06:45 AM
Volume Automation - Delay when writing touch/trim nd ICON & C|24 5 09-23-2010 07:02 AM
DSP memory blocks in "System usage" -window boijermaj Pro Tools TDM Systems (Mac) 9 10-23-2009 02:49 PM
Automation over writing problems in touch latch using a d-co Brandonx1 Post - Surround - Video 0 04-15-2007 12:16 PM
