Old 02-12-2010, 01:54 PM
Mista808 Mista808 is offline
Default Upgrade to Pro Tools 8 (with upgrade dvd) asking for Auth code? (HELP)
I've done this with another machine (crashed) and now I have a new computer (well used but new to me) It has Windows XP on it and I just got done installing Pro Tools 8 (UPGRADE DVD) I don't recall the DVD upgrade coming with a authorization code but after install/restart it's asking me for the authorization code.
It says it can be found in the "getting started guide" which I didn't get with the pro tools upgrade, only with the 7.0 that I have. It also says In Software upgrades it can be found in the inside cover of the "Upgrading to Pro Tools Guide."
I don't have either... the DVD upgrade only came with the Pro Tools 8 DVD, and then the other DVD for bundled software.
I'm not sure how to get this installed now? I don't recall ever having an authorization code for the Pro Tools 8 upgrade DVD I have. WHAT TO DO?
PS - I bought this PT 8 upgrade DVD back in November, and it let me install it just fine on the computer that I had that crashed last month. I don't ever remember having to enter an Auth code.
Old 02-12-2010, 01:58 PM
necjamc necjamc is offline
Default Re: Upgrade to Pro Tools 8 (with upgrade dvd) asking for Auth code? (HELP)
Did you try installing 7.0 first then using the upgrade?
Old 02-12-2010, 02:31 PM
sw rec sw rec is offline
Don't install 7.0 first if you're going to go with 8. 8 requires you to UNINSTALL previous versions anyway and you'll just be wasting your time. 8, even though it's called an upgrade, is a full installer that requires that no previous versions are in place.
Did you register your product? Set up a "my digi" account? You should be able to retrieve your code there.
Old 02-12-2010, 02:40 PM
DeyBwah DeyBwah is offline
If you registered your copy, you can log in here and it should have all your auth codes.
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts."
-Albert Einstein
Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub
Auth Code lost in upgrade? TrevorFWiggins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-31-2010 12:27 AM
HELP Downloaded Pro Tools Upgrade, Code No Where to Be Found chillax69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-04-2008 09:17 AM
Need Auth code for downloaded 6.4 upgrade Where??? H. Vincent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-13-2005 06:46 AM
Help!!!! 6.2.2 to 6.4 upgrade!!! auth code!! Pettenatti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-30-2005 02:19 AM
LE 6.4 upgrade auth code? validate? bonehead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-01-2005 10:37 PM
