Old 08-03-2006, 09:14 AM
Aquarius Aquarius is offline
Default VCA group : please explain..
I've never used a "large forrmat console" so my understanding of VCA groups / faders is very little.
Could someone please chime in to explain the whole story ?
What use would it be in my sessions ?
Why is it different from groups as we knew it with PT ?
Cheers,
A
Old 08-03-2006, 09:37 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: VCA group : please explain..
A quick explanation..
With VCA faders you can assign them to track groups and control the volume and mute of those tracks regardless of their output assignments. it will simple control the volume and mute for any tracks assigned to the group, so group your tracks together as you normally would and then assign the VCA to control that group.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 08-03-2006, 10:15 AM
Hi Chris,
I was wondering something like that : thank you !
But...Imagine you have your tracks grouped and assigned to a sub Bus aux track :
What then is the difference with the VCA ? I know VCA don't pass audio, nor use PI ?
Should I then have to control that sub Bus aux track with VCA.
Also, It's not clear what the VCA meter show ? PT manual says it's the louder signal amplitude...
Cheers,
A
Old 08-03-2006, 11:37 AM
crizdee's Avatar
Hi Chris,
Cheers,
A
If the tracks/group etc is assigned to a common bus, then there is no real advantage to using a VCA fader, unless you want to trim all tracks levels by a common amount etc and stuff like that! or you want to adjust tracks plus the sends when set to post fader. we'll all find ways to use this new feature
The new VCA faders are going to be a blessing to those who mix out of the box!? as they will be able to adjust volume/mute grouped tracks that are all assigned to different outputs and fed to an analogue or digital console etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-03-2006, 12:09 PM
Produce_Dept Produce_Dept is offline
The meter on the VCA will display the highest signal in the VCA group's level.
If all the members of the VCA groups have the same track number (ie stereo, mono, or surround) than the VCA will have meters with the same configuration.
If there are many different track configurations (more than one) it will default to a mono meter.
If my memory serves me!
Kurt Bullock
PT 7.4 HD2Accel Digi ProControl
G5 Dual 2.7 3.5gig RAM OS10.4.8
www.zeropointrecording.com
Old 08-03-2006, 02:21 PM
tlester tlester is offline
Chris
And I'm assuming since it's digital, it'll happen without the "ugliness" of the actual VCA in the signal path!!!
-Tom
http://SpeakRecords.COM
Old 08-03-2006, 02:42 PM
crizdee's Avatar
Chris
-Tom
Call it CCA code controlled amplifier
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-03-2006, 02:50 PM
Peter Duemmler Peter Duemmler is offline
Thr greatest advantage of VCA groups over normal subgroups to me is that they control the tracks´ level, not the group level.
Because of that the tracks´ post fader aux sends will be affected by the VCA groups level.
Peter
http://www.merlinsound.de
Old 08-03-2006, 03:24 PM
Mark Wheaton Mark Wheaton is offline
Is there any resource we can go to to better understand this new feature?
Old 08-03-2006, 04:20 PM
SessionKat SessionKat is offline
Couple 'o things regarding the new VCAs....
VCA tracks use NO mixer plug-in resources (instead of having to use busses and aux tracks for a sub group output control, which DOES use mixer plug-in resources).
VCA are their own new track type (duh!) which can be displayed by themselves, (and/or have their members 'spilled') onto ICON controllers. Very powerful.
They come in tremendous benefit after your group members relative automation rides have been written, as in the final mix stage you can show your VCA's only and get that final overall levels (Drums, Bass, GTRs, VOX groups) while keeping the relative automation rides/offsets of the group members.
Enjoy!
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Can someone please explain.... Terry Wetzel Pro Tools 9 2 12-12-2011 05:02 PM
Can somebody please explain? chicken macOS 2 10-31-2011 03:07 AM
1 track in group isn't responding with group! gregwor macOS 7 01-25-2011 08:22 PM
Could someone explain me something about ADC please? mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-21-2008 05:14 PM
Group Persists for Resizing Even When Group Turned Off. holden Pro Tools TDM Systems (Mac) 3 06-24-2008 04:31 PM
