Old 11-06-2015, 06:33 PM
connor@@vid's Avatar
connor@@vid connor@@vid is offline
Default Re: Delay compensation ignored on commit?
total delay value on the source track?
Old 11-06-2015, 06:35 PM
HMA HMA is offline
the total delay(compensated) on the original track was about 3500 (orange color)
Old 11-06-2015, 06:38 PM
ok, there may be a particular plug-in we need to look at. I would systematically make inactive one plug-in at a time and attempt commit and see if you can identify what is pushing it out of sync. are you seeing sync issues with any other tracks? Also do an online commit and an offline commit and see if there are any differences. Once you know which plug-in may be impacting it, the data point of online vs offline commit may be helpful to know
Old 11-06-2015, 06:43 PM
HMA HMA is offline
ok I keep on studing. The dly value is exactly 3545. I think I had a bigger offset around 6 ms with Waves DeBreath, which is causing dly over 35000 (red color)
Old 11-06-2015, 07:05 PM
Eric Lambert's Avatar
Just thinking outloud here...
We all know that delay comp has limitations when playing in real time, hence the red indicator when the delay becomes greater than what PT can compensate for, but "commit" isn't harnessed by real time hardware/software/CPU attributes so why shouldn't it be able to align itself appropriately with the rest of the track when converting to audio, regardless of the delays?
Old 11-06-2015, 07:57 PM
Sardi Sardi is online now
Good question Eric.
I'm also curious as to why there's a limitation in this regard.
Old 11-06-2015, 09:03 PM
LoZion's Avatar
LoZion LoZion is offline
Yes and no to Eric's statement. If you unselect offline in the dialog window, then you should be able to commit with outboard inserted on tracks with proper delay compensation applied to the new tracks. Same with offline for plugins. Otherwise it defeats the purpose and would be unfortunate..
No more quick punch routing trickery to print external outboard..
"The secret in life is to have no fear"
Fela Anikulapo Kuti
Old 11-07-2015, 05:52 PM
Danny Caccavo Danny Caccavo is offline
Pro Tools "commit" should match what the mixer can do in real time. It doesn't make sense for Commit to do something you can't do in real time. It would be confusing because of its inconsistency.
Old 11-07-2015, 09:12 PM
I strongly disagree and can't find any single reason why the two need to match. There should be an evolution of this technology, not an adherence to an unnecessary and antiquated limitation. What would be the practical point of that? When we make the decision to commit a track we've left real-time audio for good reason and we want audio in sync.
In fact, "commit" could become a NEW option for situations when a track is forced to cross the compensation threshold. I'd even argue that it makes zero sense to limit this function artificially IF ProTools is able to compensate for any delay when freezing tracks.
Out of curiosity, how does Logic deal with this?
Old 11-07-2015, 09:20 PM
The hardware limitation I was referring to was CPU horsepower, which plays a role in the buffer settings we're able to select. Outboard gear is another issue, but shouldn't hinder delay compensation when bouncing offline.
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 04:35 PM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 12:10 PM
To Commit or not to Commit, that is the question. georgejw22 Pro Tools 10 10 12-20-2011 06:30 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-06-2010 12:00 AM
Delay Compensation - Delay Monitoring when REC Howardk Pro Tools TDM Systems (Mac) 2 06-18-2006 09:59 PM
