Old 10-08-2010, 01:14 AM
lifer lifer is offline
Default HD Native. Offline bounce/Freeze?
Now we have a pro native solution, surely it will be possible to implement both offline bouncing and track freezing more easily in the future?
As I understand it that was/is a limitation of all DSP based systems because of their real time processing nature?
Win 7 Pro 64
PT 10 HD, HD4 Accel
Jetway JNAF92-Q67
Intel 2700k 3.8ghz
16GB Crucial Ram
Old 10-08-2010, 01:21 AM
GS-DK GS-DK is offline
Default Re: HD Native. Offline bounce/Freeze?
In that case I would consider to go Native. I hate realtime bounce.
Old 10-08-2010, 06:31 AM
FajitaTone FajitaTone is offline
If you use hardware inserts, how can you do a non-realtime bounce?
Ray Trujillo
Freelance Audio Engineer
Old 10-08-2010, 07:06 AM
derF derF is offline
Offline bouncing isn't all it's cracked up to be. Been using Logic a lot recently and always do realtime as various things don't come out right otherwise.
Old 10-08-2010, 07:30 AM
suicune suicune is offline
+1
In fact we had to switch to bounce 2nd cycle pass as the automation kept misbehaving in cycle mode so it now takes twice as long as PT. And even if you do offline bounce it only uses 1 processor so if your session is heavily loaded and you have lots of cores it can take far longer than realtime.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 09:29 PM
Offline Bounce DonaldM Pro Tools 11 6 11-17-2013 08:56 PM
Screen freeze, control 24 offline and RTAS overload messages fresh Leopard- PT8 crizdee Pro Tools TDM Systems (Mac) 41 03-01-2009 10:39 PM
bounce in Logic4.5=OK/bounce inPT5.0.1=FREEZE plenky Pro Tools TDM Systems (Mac) 2 09-01-2000 10:06 AM
bounce in Logic4.5=OK/bounce inPT5.0.1=FREEZE plenky Pro Tools TDM Systems (Mac) 0 08-31-2000 04:01 PM
