Re: Win-10 - Leaves a lot to be desired!
No Win 10 issues here. Runs all day every day.
Same here. I would be running LTSB except the Avid driver signing doesn't work. Drivers work fine in Creator. full blown Creator runs no less as well even with all the extras Microsoft apps. Sent from my iPhone using Tapatalk Pro |
You have obvious problems. I build a LOT of systems and Windows 10 is probably my favorite OS give or take a couple minor quirks that are fixable with other apps. Windows 10 is (can be) very fast. I would never recommend updating a system for major version updates though. Clean installs are always best.
I sell audio optimized versions of Windows 10, but you have to get the hardware with it ;-)
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
I tweak Win10 pretty hard. It has a lot of unnecessary background stuff running and I do quite a bit in the registry, power settings, USB performance specific settings, there is quite a bit. Most everything from the Win7 days and quite a bit of 10 specific stuff. It makes quite a difference.
I am having zero problems with my Win 10 installation, and it completely kills my previous Mac systems I have had in terms of Pro Tools performance. I have been building systems for 22 years though, and did some research into what chipsets and video cards work well for PT systems.
BTW I always disable power saving features on my recording rigs. MacOS and Windows. G |
#16
#17
Long before I made the jump, I asked in this forum about what things I'd need to consider in upgrading. If someone mentioned doing it as a clean install only, I did not see it. It would be nice if Avid would have provided more guidance about Win-10 for their users. If the Win-10 optimizations listed on the Avid webpage aren't enough, then they should change it and add ALL the changes required. It should not be the case that one needs to be a software engineer or have the level of expertise a software programmer has in order to get Pro Tools to operate correctly and error free in a common OS environment. If I had known there was a pre-configured version of Win-10 out there, I might have gone that route.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#18
When I first went to Windows 10, the upgrade from Windows 7 was the best I'd ever experienced to be honest. I went the upgrade route to get the free license from MS. I don't recall there being anything that didn't work for me, just had to go through the Optimisation Guide again, and I think a workaround to get the legacy firewire drivers.
I ended up formatting and starting fresh shortly after anway as I bought an SSD, and it was a good opportunity. On a side note, I just picked up an older used HP computer, and the free upgrade to Windows 10 still works, just punch in your Windows 7 key during install. That was from a clean install too! Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
#19
I could not really expect Avid to break it down to this level. Avid has to assume our OS installs are working properly. There is no way to test every possible configuration. Its one of those things, it may work fine for person A, but person B may have problems. No disrespect and not trying to sound rude with the above As far as "audio optimized", It was more sarcasm. I was referring to our Pro Tools PC's. The systems are heavily configured and optimized.
#20
Part of my frustration is that it feels like no matter how careful I try to be to understand and read up on everything I need to do to have things optimized for Pro Tools and audio, and no matter how carefully I try to make sure all things in my system are compatible and meet the requirements, there's always some OTHER thing that should have been done that I didn't read about, or wasn't told or whatever. Its like if you're not a computer software engineer, its not possible for you to actually use Pro Tools. That's how it often feels. I'm sick and tired of having to trouble shoot some new thing every single day, or having some new problem pop up. Today, I turn on my PC, and Win-10 tells me it can't open my account. I'm the only friggin' account on the PC for Pete's sake. So I reboot, Windows comes up, but several of my Desktop icons are just missing...like Pro Tools for one. The programs are all there, but my Desktop layout is all different. Its stuff like that, which I have no way to explain, that drives me nuts. I didn't change anything on Win-10 other than what was the suggested optimizations. And then this. I just don't get it!
9.01 cannot select desired default output bus | gonzolagonda | Pro Tools TDM Systems (Mac) | 5 | 03-14-2011 07:56 AM |
Xmon leaves a lot to be desired | sburrows | ICON & C|24 | 12 | 04-24-2006 10:19 AM |
Killer Vocals desired | techbeat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-02-2005 03:45 AM |
what is the desired sample rate to record with? | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 07-31-2002 01:37 PM |
MORE FIREWIRE INFO DESIRED | LidMan | General Discussion | 1 | 07-23-1999 03:55 PM |
