Old 05-18-2017, 11:24 AM
oortone oortone is offline
Default Re: Does twin ethernet adapters work
Originally Posted by EddieJones View Post
You could plug them into the router where your wifi is, there should be 4 ports on it.
Unfortunately it's completely impossible to plug the Artist to the router. It's an another floor (wooden house) so I will need to connect ethernet to the MacBook directly.
So which is to prefer if I don't use a twin USB-to-Ethernet adapter? Switch or Router?
Old 05-18-2017, 11:33 AM
EddieJones's Avatar
Personally I would go with something like this https://www.amazon.com/TP-Link-Gigab...switch+gigabit
Old 08-03-2021, 01:36 PM
Coming back to my old thread:
I ended up buying a USB-to-2x-Ethernet adapter and that was a big mistake. It will work, but from time to time it will also not work and I have no idea the reason why.
What I do know is that if I use only one port of the adapter and use a switch to reach both Artist Mix it will always work.
So twin-adpaters does not seem to be a good idea. I wanted to minimize my setup but it seems that I do need an additional switch to get rid of network trouble.
Maybe the EuCon-application can not handle two ethernet ports on the same computer?
Eucontrol 3.5 - the ethernet solution when wireless WON'T WORK nlaflamme Avid S1, S3, Dock and Control App 1 03-19-2017 09:05 PM
Does Eucon actually work with a usb/ethernet adaptor? robertg Artist Series 1 07-23-2015 11:36 PM
Apple ethernet adapters Thunderbolt vs USB tams Artist Series 1 05-04-2015 04:25 AM
Will Control 24 work with USB to ethernet adapter ? VIKING ICON & C|24 3 08-30-2009 03:13 PM
C24 wont work. No ethernet drivers. juzbag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-02-2003 01:37 AM
