Help!!! Impulse Responses?
If anyone here can help me I will offer them my first born.
I am running Pro Tools 6.2.2 on my Powerbook G4. Just the other day I bought an EZQuest Cobra Pro Audio external hard drive. I ran a session the first night and everything was beautiful. Yesterday I did some mixes and everything was still beautiful. I quit Pro Tools and when i tried to open it later, Pro Tools took about 5 minutes to open, getting choked up when loading the Plug Ins. When it was finally opened I tried to open the session and a window came up reading "Please select the folder containing your Impulse Responses" I have no idea what this means and no matter what folder I choose, it begins to open Pro Tools and then the application unexpectedly quits. Has anyone here experienced anything like this? My suspicions are as follows: 1.) A friend of mine recently loaded a bunch of cracked Plug Ins on my computer, but that was a month ago. The one time that i was able to open a session in the last 24 hours was when I opened an old session that doesn't utilize any of the cracked Plug Ins. Still it took 5 minutes to open the program. Could this be a cause, and if so, what do I do? 2.) Does a new drive ever corrupt a program? This may seem like an ignorant question, but the new hard drive is the only new addition since this problem has begun to occur. Any insight would be a life saver. Thanks Jeremiah |
Re: Help!!! Impulse Responses?
Sounds like you had a bad plug-in on your system... Since the only cracked software I've heard of which uses Impulse Responses would be Altiverb.. I'd try removing that from your system.
Other plug-ins which use Impulse Responses are TL-Space and Waves IR-1. Take this as a warning to be afraid of crack. Rail
It's most likely a result of an Altiverb crack. The Impulse resonses folder should be (I think) under Library>Digidesign>Plug-in Settings.
If choosing the correct folder doesn't resolve your problem then move that plugin to the unused plug-ins folder. Avoid using cracks. . .they'll greatly deppreciate your system's stability. |
Impulse Responses | 2hip2b4real | macOS | 1 | 05-16-2012 08:05 AM |
OT/impulse responses | clusterer | Post - Surround - Video | 4 | 12-03-2009 10:18 AM |
TL Space Impulse Responses | GuyPicks | Pro Tools TDM Systems (Mac) | 4 | 01-26-2007 06:58 PM |
TL space- Impulse Responses | bmuth | Pro Tools TDM Systems (Mac) | 3 | 11-07-2005 10:09 PM |
my impulse responses | Chris Cavell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-04-2004 08:08 AM |
