Old 09-17-2020, 02:58 PM
Snafu Snafu is offline
Default Sudden Issue With Playback on One Session
Hi guys!
Been working on this track for a good two months and getting very close (famous last words!)...all of a sudden pressing play takes the session to an imaginary bar -1978 and its impossible to get it to play on the actual session. Changing session start time does't help anything, nor changing the link timeline and edit/track and edit.
1.Does anyone have any ideas? Never seen a weird bug like this before if it is a bug. I wasn't really pressing any strange keys or anything when it happened.
2. If not, is the easiest way to hopefully fix this to copy each track/session data on a new session via the import track command?
My other sessions play back fine.
Thanks as always!
Old 09-17-2020, 03:00 PM
Default Re: Sudden Issue With Playback on One Session
Tried saving a copy of the session, and the copy has the same issue.
Old 09-17-2020, 03:03 PM
Oh God copying session data also causes the same problem, starting to really worry now!!!
Old 09-17-2020, 03:10 PM
Ben Jenssen's Avatar
If you look at min/sec, is that one hour?
If so, that might be a clue.
I remember having session start move by an hour, back in PT8/10 days.
Old 09-17-2020, 03:13 PM
Hi Ben, thanks for your reply.
No, it says 8C859:59:99...yes 8C is not a typo!
Even exporting selected audio and importing it in a new clean session brings the issue with it!! All other sessions still work perfectly. Going a little crazy.
Old 09-17-2020, 03:16 PM
Damn it...old sessions do work fine, but importing anything on new sessions now causes this problem. This is all started mid session without touching anything haha...so weird.
Old 09-17-2020, 03:17 PM
Except for the "C8", that seems like pretty much like an hour to me. I think this is solvable.
Old 09-17-2020, 03:21 PM
I can remember this thing happening, but unfortunately I can't remember what was the cause, and how we fixed it. But we did...
Each bar is two seconds so i think the maths do work out to be an hour if you ignore the 8c! *1799 bars at 2 seconds is 3600 seconds right?)...Your optimism is very comforting through these dark times!
Old 09-17-2020, 03:23 PM
Haha ok this is promising i guess Did you freak out as bad as i am freaking out now? If you get any flashbacks I doubt i'll sleep over the next few months til i figure out what it is:)
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Sudden issue with 003 and low latency Linusoli Pro Tools 10 0 08-27-2013 02:48 PM
Crazy Session - Playback Timing Issue Craiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2010 02:39 PM
Sudden Issue Opening ANY .ptf in 7.4 stackjones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-12-2008 07:15 PM
no playback all of a sudden sojay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-16-2002 09:50 AM
