Old 08-25-2001, 10:05 PM
dcarlson247 dcarlson247 is offline
Default Digi 001\'s line level inputs 3-8. Control input?
On page 32 of the "Getting Started with DIGI 001" in the "Analog Audio" section it says that for line level inputs 3-8 on the back of the I/O box, the "Digi 001 includes software controllable gain to accommodate the different line levels that these devices can generate."
Does anybody know where this software control is?
Thank you
Old 08-25-2001, 10:41 PM
pk_hat pk_hat is offline
Default Re: Digi 001\'s line level inputs 3-8. Control input?
In your main ProTools folder, there should be one called DigiGain, and an installer for it.
There's also a dialog box in the Hardware Setup menu in PT, and within that, a sub-box titled 'other options'. Click on that and you can then raise or lower the gain inputs.
hope that helps.
pk
www.myspace.com/krou
Old 08-26-2001, 02:04 PM
Thank you pk_hat. The 'other options' in the hardware set-up was exactly what I was looking for to let me adjust the input gain for 3-8.
I didn't find DigiGain in the main folder but I am aware of and have used the 'gain' plug-in that was already installed with the program. I needed to lower a level coming in from a Roland 1680 so the hardware adjust is going to work perfect.
I appreciate your response a mere 36 minutes after the question was posed.
dcarlson247
003 Rack DI inputs as line level littlegreenmen13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-28-2012 01:42 PM
Inputs 1-4 used as line-level on 003 Rack Everything 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2007 06:34 AM
ProjectMix 1/4" Inputs Truly Line Level ? 2012 Pro Tools M-Powered (Win) 0 07-05-2006 09:10 AM
002 - can't get decent record level on line inputs swiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-11-2005 02:22 PM
can i run a line level into a hi z input ??? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-17-2003 02:37 PM
