Old 04-16-2020, 09:45 AM
Default Re: Midi Notes "grey"
Originally Posted by JFreak View Post
Okay then.
Just accept that perhaps your unsupported configuration has made this bug worse than it is. If you are running 11.3.1 the max.supported OS is 10.10.3 and if you are using 10.14.6 the minimum PT version you need would be 2019.5
Downgrade OS or upgrade PT, then try again.
Part of the problem is the OP hasn't given us a complete exact run down of his system like exact PT version and exact OSX version.
Jack
QAPLA!
Old 04-16-2020, 09:46 AM
Southsidemusic's Avatar
Originally Posted by hardcoresuperstar View Post
you know that there are more than one way to work with midi?
But Ok, i will do it your way!
Well it is not ”his way” as PT is set up so you dont need to bother with midi tracks since instrument tracks are a Midi track but programmed so you can use them with Plugins which cant be used on a midi track so, your way is doing the same thing twice basically.
The midi tracks are also for external synths and outboards in conjunction with audio tracks but Instrument tracks has all that for the user already.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
JFreak's Avatar
JFreak JFreak is online now
Wat? Isnt it on post #1 or am I seeing things
Janne
Old 04-16-2020, 09:50 AM
Yeah it is there so your eye sight is still working
and that combo is not adviced at all. May well be PT11 with Mojave that is causing glitches. I would do what Janne said to either upgrade PT, downgrade OS.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-16-2020, 10:27 AM
When I called the OP on that system info he replied in post #3 and said he got a PT upgrade but didn't say what that upgrade is/was. Got to love not getting complete accurate info when trying to help someone.
Jack
QAPLA!
  #16
Old 04-16-2020, 12:39 PM
hardcoresuperstar hardcoresuperstar is offline
Okay then.
Hi, i am running 10.14.6 and pro tools 2020.3.0
so the pics are from that configuration.
  #17
Old 04-17-2020, 08:11 AM
Hey i got new infos.
It seems like the "clip" is muted. When i set notes outside from the "clip area" then the notes play perfect.
Look at the new pic
And the clip ist not muted or volume down or something. i checked the drop down menue where you can see clips, verlocity etc
JE
File Type: jpg Bildschirmfoto 2020-04-17 um 17.06.34.jpg (41.3 KB, 0 views)
  #18
Old 04-18-2020, 04:11 AM
Look at the new pic
JE
I mentioned that the notes were muted in my first reply - glad you caught on to it.
Jack
QAPLA!
  #19
Old 04-19-2020, 03:39 AM
Hey Guys - Many Thanks for your help.
Difference between "Midi Studio Setup", "Midi Input Devices", and "Midi Controllers"? GOOOTOOO Pro Tools 2020 5 04-01-2020 01:23 PM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Keyboard shortcut to toggle "Play MIDI Notes When Editing" Soul Finger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2010 06:29 PM
Probable bug in "notes" view on midi channel with smart tool farmfresh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-30-2009 11:07 AM
Why is my "Midi Merge" button grey? I don't have the option to press it. Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-19-2009 05:57 PM
