Old 11-21-2018, 11:11 AM
Henning Svoren Henning Svoren is offline
Default Logic 10.4.2 not working with HDX anymore?
I am just curious if anyone have used Logic 10.4.2 with HDX as an interface?
I had it working a month ago, with 10.4.0 or 10.4.1(can't remember which), but unfortunately I "upgraded" to 10.4.2.
I can choose HDX as an input/output device in Logic but I can't get any sound into the inputs.
I've tried both with HD Driver 2018.7 and 2018.10.
I have a second system with the same kind of trashcan Mac Pro(Sierra 10.12) and software, but with HD Native TB. On this system i can get sound in/out of Logic 10.4.2.
www.oceansound.no
Old 11-21-2018, 11:38 AM
Default Re: Logic 10.4.2 not working with HDX anymore?
Originally Posted by Henning Svoren View Post
Are you on Sierra on both? Just guessing: Was one upgraded recently to Mojave? (Double check it was not) If so you need to enable microphone inputs in security & privacy preferences. Otherwise does the input work with any other Core audio app?
Old 11-21-2018, 11:46 AM
Thanks for the reply.
Yes, Sierra on both.
I guess I can see if can I get sound out of Izotope RX, Revoice or something.
www.oceansound.no
Old 11-21-2018, 12:00 PM
You can hammer a nail in with an anvil if you want, or I would use a hammer.
I would just use Quicktime Player>File>New Audio Recording and see if that works. Or on Mojave you can use Voice Recorder. In both cases set the Audio/Midi system audio input to the interface HDX is connected to. Make sure Pro Tools is not running/not stuck in the background. if the HDX/interface does not show up in Audio/MIDI setup with an input, well you've peeled that layer of the onion.
Old 11-21-2018, 12:19 PM
Thanks, that makes sense
www.oceansound.no
Old 11-21-2018, 10:26 PM
Stig Eliassen's Avatar
Works just fine here, Henning. Details in the signature.
Old 11-22-2018, 04:07 AM
Good to hear that!
I guess I must have messed up somewhere along the line.
www.oceansound.no
Old 04-16-2019, 07:01 PM
KingFish KingFish is offline
I'm having the same situation with OS X 10.14.4 Mojave, with Logic enable in Microphone security. With Logic 10.4.4 and Pro Tools 2018.10 HD Driver on HDX Hardware.
This "Just worked" last year, in high sierra, but I'm definitely not getting any sound out of my HDX HD i/o HW when selecting HDX in Logic, but getting audio out of Built in output, or a Presonus USB96 box when hooked up.
Anyone using the Latest Pro Tools / w/ the Latest Logic, on the Lates Mojave with HDX HW ?
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
ASIO not working anymore tobiasl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-24-2010 09:28 PM
ctrl,cmd and k is not working anymore? lowq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-29-2009 10:54 AM
vst2rtas not working anymore... peter99 Pro Tools TDM Systems (Mac) 4 09-18-2008 04:03 PM
OMF from avid 11.0 to LE, not working anymore, help kalil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-17-2003 01:21 PM
PT 5.01 + OMS + Logic 4.5 don't work anymore! smcoptyltd Pro Tools TDM Systems (Mac) 4 10-17-2000 10:13 AM
