Old 06-21-2018, 06:46 PM
jryser's Avatar
jryser jryser is offline
Default Re: -9093 stops are killing me!!!!!
Originally Posted by ZEUSS View Post
It is lol! Its like the old ADAT days all over again with ERROR 7
HATE-dats
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 06-22-2018, 01:24 AM
Rammelt Rammelt is offline
I couldn't run any type of Session at all without the errors on my i7 MBP Retina, no matter how few tracks and plugins, but then I installed Turbo Switcher Pro to disable Turbo Boost while running Pro Tools and suddenly I could run very heavy Sessions without problems.
This has been a fact for me since PT 12 and a few OS versions.
My $0.02
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Old 06-23-2018, 04:35 PM
The Weed's Avatar
The Weed The Weed is offline
albee,
I'm pretty sure you're not, but if you are running Windows Defender, Controlled Folder Access was added with the April 2018 Update. Turn that off.
Also, Disable SuperFetch and Windows Search in Services.
HTH
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-23-2018, 07:00 PM
Originally Posted by The Weed View Post
albee,
HTH
Hmmmm, the errors have been going on for a long while, but may have gotten worse since the update. Disabling Superfetch sounds easy, but can you expound on Controlled Folder Access?
Old 06-23-2018, 09:08 PM
The Weed's Avatar
Controlled Folder Access is part of Windows Defender. It's under Windows Defender>Virus & Threat Protection>Virus & Threat Protection Settings>Manage Controlled Folder Access. It's Ransomware Protection and you can turn it On or Off, add Protected Folders and add or remove Allowed Apps. When it's turned on it stops any app/program that's not "Allowed" from making changes to the Protected Folders.
Obviously, if you're not running Windows Defender you don't need to worry about it. I have it "On" for my Work computer and "Off" for my Audio computer. I also now backup to an external drive and unplug that when done as well as have the paid version of Macrium Reflect which has Image Guardian, which is supposed to stop any Ransomware or Malware from encrypting any Macrium Reflect Image that's on a drive that has Image Guardian enabled on that drive. I unplug the drive because: If it's not connected it can't get infected.
SuperFetch and Windows Search are both under Control Panel>Administrative Tools>Component Services>Service (Local)>Standard Tab. Double Click on the Name, then set Startup type: Disabled and Service status: Stopped, then Apply and Okay for each.
SonoBus
  #16
Old 06-24-2018, 03:27 PM
PatriotsBiker PatriotsBiker is offline
@The Weed: Thanks for the tip of naming two Windows' Services to disable. I had CPU usage reduction according to PT's System Usage window.
@albee1952: Are you still running smoothly?
  #17
Old 06-24-2018, 04:13 PM
The Weed's Avatar
My pleasure.
If you're using a backup program - you really should be - and you have Windows 10 Pro, use the Group Policy Editor to also disable System Restore. That too may save you some CPU cycles.
SonoBus
  #18
Old 06-25-2018, 10:57 AM
Will let you know after I implement Weed's advice
  #19
Old 06-25-2018, 05:27 PM
zedhed's Avatar
zedhed zedhed is offline
Maybe this could be of use?
http://duc.avid.com/showthread.php?t=399944
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
  #20
Old 06-25-2018, 08:11 PM
My pleasure.
Thank's again, The Weed. I will look into that one as well.
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 11:43 AM
11R killing PT thegreyfox Eleven Rack 3 04-24-2012 09:34 PM
This is KILLING me! audiogeekzine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-22-2008 04:10 PM
-9093 error's killing me!!! coryc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-04-2003 03:24 PM
-9093 Error, CPU stops rec., says buffer problem? storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-16-2003 09:33 PM
