Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-15-2016, 12:32 PM
secutanudu secutanudu is offline
Default Speaker for custom Sub-Kick
Hey all,
So I'd like to make a sub-kick mic. I know the "standard" is an NS10 speaker, but they are crazy expensive on the used market.
Would something cheap like a $20 pyle 8" car subwoofer be sufficient? Or would it be worth it to get a better speaker? Does quality of those low frequencies really even improve with a better speaker?
Thanks.
Old 11-15-2016, 12:59 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
Default Re: Speaker for custom Sub-Kick
I went to Parkway, bought a 8" speaker, can't remember the brand and a smaller tom shell and built it that way.
Hit me up at work if you need help.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 11-15-2016, 01:53 PM
I think any woofer between 5 and 8 inches, with a foam surround should do nicely. I used an 8" from an Event ASP8 and it rocks
Old 11-17-2016, 06:48 AM
Thanks for the responses.
So I would like to build in a 10 or 20 dB pad inside the unit. I know they make XLR fixed dB attenuators, but what's inside them? Just a resistor?
Seems like it would be pretty simple to just solder a resistor between the speaker and XLR jack - anyone know what type of resistor I'd need and where it would go (on which wire)?
Thanks!
Old 11-17-2016, 06:51 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Start here - http://www.uneeda-audio.com/pads/
Old 11-17-2016, 05:27 PM
Originally Posted by Matt Hepworth View Post
Awesome, thanks.
I guess my question, would I assume the 8-ohm rating on the speaker I plan to use would apply when using it as a microphone? The example for the 20db pad says this:
We need a microphone pad to attenuate the output of a high-output microphone that is close-miking a loud instrument. The microphone is a 150-ohm device, and the preamp presents a 1500-ohm load. We want to lose 20 dB in the pad.
Would it be safe to assume I can build my pad in the same way they did? Or will I attenuate way too much/not enough?
Maybe I should just buy one - but I thought it would be fun to try building my own. Maybe even making a 10/20 db pad with a switch.
Thanks.
Old 11-17-2016, 05:38 PM
Or maybe this would be even easier?
http://www.parts-express.com/parts-e...8-ohm--260-262
Old 11-17-2016, 06:46 PM
You may not need a pad(unless you have already built and tested). A few folks I know that built this kind of unit have reported needing a lot of gain
Old 11-17-2016, 06:57 PM
Interesting. Everything I read seemed to suggest it was necessary.
Did you find that you needed one?
Old 11-18-2016, 09:45 AM
I did, but my preamp has a Pad button. Its going to depend on the woofer used.
ASIO4Alll audio is computer out of computer speaker and not rear speaker willl3 Windows 6 07-31-2012 10:50 AM
Aggregate I/O Built-in Speaker causing speaker to crack and pop andrewkeithly macOS 2 01-27-2012 11:10 AM
Novice: Kick In and Kick Out question Nils Groth Tips & Tricks 3 01-10-2009 07:33 PM
Adding a kick sample to an existing live kick performance paul Neathery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-12-2007 03:16 PM
Senheiser MD 421 or Shure Beta 52 for kick drum?r kick drum mic? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-16-2001 07:07 AM
