Old 11-20-2015, 12:19 PM
minister's Avatar
minister minister is offline
Default Clip Bin trick for Pro Tools
Maybe others already know this, but it was new to me. Well, my editors figured it out years ago and never told me, the blaggards! Reason I didn't know it is because I drop Soundminer transfers right on to the timeline and never work this way. One day I walked in and was trying to figure out what he was doing. And today I had a use for it.
If you want to easily populate the Clip Bin with only the recent transfers, pull up the Clip Bin search box (shift-cmd-F), then hit the spacebar a couple of times so the "search" it pulls up is null. Now transfer audio files. Only those audio files will be showing in the bin. Now you can easily drag just those files on to tracks.
Maybe this works in Nuendo or Reaper too.
For the times when you might need something like that...
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 11-20-2015, 05:31 PM
reichman's Avatar
reichman reichman is offline
Default Re: Clip Bin trick for Pro Tools
Cool. I would never have thought of that.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 11-22-2015, 07:38 PM
FajitaTone FajitaTone is offline
I go one further and have sound miner add prefixes to transfers so I can separate and search only specific groups of effects.
Ray Trujillo
Freelance Audio Engineer
Old 11-23-2015, 09:54 AM
Tstein Tstein is offline
Another option (independent of Sound Miner) is to go to the CLIPS (clip bin) pull down menu and select; Sort by - File Modification Date. Then select; Descending. Your most recent additions to the bin will appear at the top of the list.
Old 11-24-2015, 07:14 AM
antonis's Avatar
antonis antonis is offline
Same thing here. I've been adding "sfx", "pfx", "adr" suffixes for years now. Now the good thing is, and not a lot of people know that the clip bin search function gives you the ability to save entries with the session. I have a set entries with my template and I usually add more along when working with radio dx (using the names from the field recorder metadata) or a language prefix when working with multi-language sessions.
Old 12-18-2015, 10:07 PM
philip_purcell philip_purcell is offline
All good workarounds, but begs the question, why does Protools not allow multiple bins, like Media Composer (and every other NLE) have had forever. So you could sort your clips into dialogue, music, sfx or anything else you wanted. We have been asking for this for years, along with a clip editor, with no joy.
HTML code is On
x form rendering blank files when choosing clip by clip audiosuite dj_grimmace Pro Tools 11 1 03-04-2017 12:35 PM
Eleven Rack With Another Interface & Pro Tools 11 Trick Becharax Tips & Tricks 4 07-25-2013 05:27 AM
Simple-ish but Cool Trick (pro tools and logic) TheSetup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2009 09:21 AM
Bizarre Disappearing Pro Tools Trick Analog Kid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-25-2008 12:41 AM
Pro Tools Mac Trick Ke productions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-31-2005 12:17 AM
