Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-10-2015, 06:23 AM
mickeyrouse mickeyrouse is offline
Default Getting started with drum triggers
Let's assume I know absolutely nothing (very safe assumption) about using drum triggers in recording. Where is a good place to go to break in to this?
Old 11-10-2015, 07:15 AM
amagras amagras is offline
Default Re: Getting started with drum triggers
Since you are asking here you probably expect more specialized advice than I (or YouTube) can offer but anyway here are my 2 cents: duplicate the track, insert the trigger in the duplicate then lower the volume of the duplicate all the way down and then increase it until you are satisfied with the blend. Alternatively you can route both tracks to an aux channel for further processing.
Make sure you have delay compensation enabled!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 11-10-2015, 07:55 AM
On the off-chance you meant drum triggers, as in placing trigger sensors on a regular drum kit; they need to connect to a trigger to midi interface, as made by Ddrums and alesis, or most any old E-drum brain like a Roland TD5, 7, 9, 10, 20, etc. The brain would be connected to your system via midi cable or USB(depending on how new it is. Both work fine). Then you create a midi instrument in PT>setup>Midi>Midi studio. Call up a stereo Instrument track and insert a drum VI(like EZdrummer), put the track in record-ready and hit the drums. You SHOULD be hearing the plugin drum sounds, if the pad-note assignment is correct
Old 11-12-2015, 09:50 PM
Aha! Wisdom and guidance shineth!
Drum Triggers costas.themis The Drum Room 2 01-25-2012 03:12 PM
drum triggers?? bluesguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-17-2005 07:37 PM
drum triggers MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-10-2005 09:30 AM
Slightly OT, drum triggers.... hornedrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-08-2005 03:02 AM
drum triggers and sampled drum sounds SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-05-2000 11:11 AM
