Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 04-19-2015, 08:49 AM
Matt Darcy Matt Darcy is offline
Default EZDrummer/Superior Drummer - online collaboration with midi programming
I'm working on some demos in my home studio, I'm using toontrack products to write the drum tracks pretty much only using their midi packs as I suck at drum programming.
I'm really struggling with a 3/4 track using the online midi packs as none of them have the feel I'm looking for.
I thought some of you experienced drum programmers may be interested in collaborating on a track, hell maybe even more than one by writing the drum track for me.
I've never tried this sort of thing before so I don't know how it would work, but the idea of collaborating with a stranger, maybe even in another country and time zone sounds exciting and something different, so I'd certainly be interested in hearing from any of you who have either done this before I fancy trying to see if it works.
Old 04-19-2015, 09:12 AM
Default Re: EZDrummer/Superior Drummer - online collaboration with midi programming
Check out our groove libraries
https://www.platinumsamples.com
Rail
Platinum Samples
Engineered Drums for BFD
Old 05-20-2015, 10:13 AM
Emcha_audio's Avatar
Default
YOu can find many midi file for drums online where you will get the groove you want. You can then import that midi file into yoru instrument track in pro tools and let it play through SD, or you can add it to the midi files of SD so you can play it through the browser of SD
Manny.
Wave-T.com
Old 06-16-2015, 12:12 AM
Hedleyk Hedleyk is offline
Might be worth exploring 6/8 time signatures. Divisable by 3/4 so will fit but with a different feel.
Dragging MIDI from Superior Drummer crashes PT lennieh Virtual Instruments 4 01-03-2012 01:08 PM
Midi from drums through command 8 then superior drummer Raoul23 The Drum Room 3 09-29-2011 05:15 PM
Midi tempo question (superior drummer) patswope Virtual Instruments 3 02-07-2011 05:07 PM
How do i use Superior Drummer without any midi devices ? Rwilliams0190 Virtual Instruments 15 06-06-2010 01:19 PM
EZdrummer vs Superior Drummer 2.0 - system resources nod25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-22-2009 03:05 PM
