Old 02-23-2015, 12:58 PM
shokl8 shokl8 is offline
Default message stuck on screen
I have an avid mc control, after powering up the unit the screen is stuck on the euphonix screen. Is my unit broken or is there a reset that i can do to fix this problem. I used the ethernet cord that came with the unit and also a separate cord. It was plugged into a switch and i also plugged the cord into the mac directly and still the same issue. Is there anything i can do. Thx for any help you can give.
Old 02-24-2015, 07:15 PM
FajitaTone FajitaTone is offline
Default Re: message stuck on screen
I'm assuming you have installed the EuCon software on the computer and configured it to look for the surface?
Ray Trujillo
Freelance Audio Engineer
Old 02-24-2015, 07:25 PM
Correct I did I tried everything in order from what the documentation said. I did use the newest downloadable sw. Then I downloaded the version before the latest version and got the unit to the next screen
Old 02-25-2015, 11:11 AM
Ok my Mc control has passed the euphonix screen it came up but I still can't assign functions I am so lost I might look at getting something else
Eleven Rack stuck at splash screen. MattBaron Eleven Rack 24 04-06-2015 07:16 AM
Stuck on Start Screen petergab Eleven Rack 4 04-30-2014 09:01 PM
blue screen message, btd problem guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-03-2004 10:16 PM
002 STUCK IN VALIDATING AND LOADING SCREEN (BANGAH) 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 07-23-2003 10:50 AM
