Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 12-10-2014, 07:43 AM
BradBristow BradBristow is offline
Default Roland TD-20 Kit not showing in Pro Tools
I have tried everything. It's not showing up in the midi-studio, Input devices, nothing and I've got it connected both thru the midi cord and using the master out left and right connects. I can hear the kit thru the master outs when in record mode but I can't get it to record the midi data and the unit itself just is no where in the Pro Tools set-up. I am using the 003 with Pro tools 8, Glyph 500g hard drive and the Roland TDW-20 Expanded Sound module. Any help is greatly appreciated!
Old 12-10-2014, 01:51 PM
albee1952 albee1952 is online now
Default Re: Roland TD-20 Kit not showing in Pro Tools
So you have a MIDI cable going from the Roland MIDI OUT to the 003 MIDI IN? Open Pro Tools and go to Setup>Midi>Midi Studio. Create a new "instrument" and name it Roland kit(or whatever you like). Skip the brand and model as those are not required. Select the 003 MIDI input as the input path or source. Leave all channels in blue(unless you have a reason NOT to). Select a MIDI output(one of the 003 MIDI outs) only if you want to send midi BACK to the Roland. That SHOULD get you midi going IN to Pro Tools(on either a MIDI track or an Instrument track).
To get audio, connect 2 cables from the Roland MAIN outs to a pair of quarter inch inputs of your interface(I would start with 5&6 and set the level switch on the 003 to -10. Assuming you are trying to bring the Roland audio into a stereo track, you MIGHT need to go into Setup>IO>Input tab and add a stereo path(use the Add New Path button) and click the matrix(the grid and dots) so that 5&6 show L and R corresponding to your new input path(and you can double-click on the path name and rename it to Roland Kit or similar). My preference(in the Preferences menu>MIDI tab) is to set the default thru instrument to NONE. Go to the Options menu and check Midi Thru. You will need to put your MIDI or Instrument track into record-ready to "see" midi input showing. I used a TD-10 kit for years thru my 003, with Superior Drummer, EZDrummer and Addictive Drums, and it worked great
Old 12-16-2014, 03:36 PM
YYR123's Avatar
YYR123 YYR123 is offline
thats a quality post, brad be grateful
Daniel
Old 12-23-2014, 09:50 AM
In addition to this don't forget to set things up in OSX audio/MIDI setup as well. I do something similar with my Yamaha DTXM12 hardware and 11 Rack. And don't forget to have everything talking on the same MIDI channel as well.
Jack
QAPLA!
Old 12-23-2014, 04:06 PM
Did Brad fall off the edge of the planet? Is it working? If not, post some details on your system(as of now we don't even know if you run Mac or PC)
Old 12-23-2014, 04:30 PM
YYR123's Avatar
Hit and run posters, I had one once from Taylor....
Man I think I kept posting in the thread hoping he would come back for more than 6months
Daniel
Old 12-23-2014, 04:55 PM
Those drive me nuts; you don't know if the advice you gave worked or not. Then again I think that this happens maybe because they figured out the problem on their own and it turned out to be pilot error
Jack
QAPLA!
Old 12-23-2014, 05:06 PM
YYR123's Avatar
Yeah that's true, most people never get on the forum unless they have something that's not working
What would I do with all my free time if I stopped posting?
I always seem to check the site when I'm doing real-time bounce
Daniel
Old 04-16-2016, 02:24 PM
I just read ALL of your replies to my only other post concerning my Roland TD-20 and I have to say....I would LOVE an opportunity to hang, have a beer or just visit with all of you one day. I was laughing my ass off....calling me a "hit and run poster" and all that! First, I am truly sorry for not returning to fill you guys in and I promise I will never make that mistake again!
You just did such excellent work. Got me totally up and running and I was nose down in the studio! THANK AGAIN and is there ever a 'get together' of you guys?
Brad Bristow
678-472-1619
Old 04-17-2016, 10:16 PM
Brad Bristow
678-472-1619
Glad to hear
Pro Tools 11 on mac not showing waveforms digitaltracks Pro Tools 11 36 09-12-2017 10:53 PM
Pro Tools not showing all plugs swag74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-27-2009 09:47 AM
Roland keyboard not showing up in Pro Tools dustyboots Pro Tools TDM Systems (Mac) 12 06-02-2009 04:23 AM
Plugins not showing up in Pro Tools swh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-09-2007 09:20 AM
Roland Td-7 into pro tools using M-box satchvai 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-09-2007 02:01 PM
