Old 11-20-2014, 10:02 AM
yorgo yorgo is offline
Default Pro tools 9 to 11 upgrade 199.00?????
Hey guys there are offering this at sweetwater. Pro tools 9 works pretty well for me other than the occasional error and I guess I am limited by the amount of RAM I can use.
So my question is how happy are you guys with your protools 11? Is it worth the upgrade compared to 9. 199 is pretty enticing...
Thanks
Pro tools 11.3, Windows 7 Premium,
Desktop i5 4670 3.4ghz 16G ram quad core
Old 11-20-2014, 10:16 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Pro tools 9 to 11 upgrade 199.00?????
Yes, PT11 is a huge step up from PT9. If you go ahead and purchase this upgrade before December 31st 2014 you will get EXTENDED Standard Avid Support. This is going to be a 1 year contract, but if you act now you will get coverage through March 2016!
If you are serious about Pro Tools, you will want to be on Pro Tools 11 since it is 64 bit and will run on newer computers. And since RTAS is being phased out in favor of the new AAX plugin format, you will need Pro Tools 11 if you like to buy new plugins.
http://www.avid.com/us/products/pro-...tcmp=AV-HP-S1a
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 11-20-2014, 10:24 AM
This upgrade will force you to surrender your Pro Tools 9 license. So...
0. Make sure all the plugins you need are available on AAX-64 for Pro Tools 11 (not RTAS, not AAX-32)
1. Make sure your system exceeds the minimum systems requirements for Pro Tools 11, especially memory. And OS version... and that that OS is also compatible with whatever interface drivers you need and they work with Pro Tools 11.
2. Go get the Pro Tools 11 demo, and install that on your system and test it works for you before you purchase the upgrade. Ideally do an clean OS install on a different boot partition and install Pro Tools 11 there so you don't risk your Pro Tools 9 install.
The Pro Tools 11 license also lets you run Pro Tools 10 (which still supports RTAS plugins), but that is effectively unmaintained software.
Old 11-20-2014, 10:31 AM
Benoni's Avatar
Great idea Darryl, the trial slipped my mind.
yorgo, you can get the fully functioning trial of Pro Tools 11 here:
http://www.avid.com/Trial/ProTools
You WILL need an iLok v2 for the trial license.
Keep in mind if you purchase before December 31st you get the Extended Coverage through March 2016. If you purchase after Dec. 31, 2014, it will be 12 months of support/upgrades.
Purchases of Pro Tools with Standard Support, upgrades from Pro Tools 9 and later, and upgrades from Pro Tools | HD 9 and later made after December 31, 2014 will receive one year of Avid Support, including updates/upgrades, from the time of purchase.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 11-20-2014, 01:09 PM
21 Junipers 21 Junipers is offline
And he gets 10.x with 11 right? If so, not just a choice between 9 and 11.
10 vs 11 - Some find 10.x more stable than 11. I suspect this has as much to do with functionality used/required as much as anything.
9 vs 10 - My experience has been that the latest version of 10 is at least as good as any version of 9. But as Darryl suggested, download and test if you depend on your system.
In any case it seems unlikely you'll get a better offer.
Old 11-20-2014, 01:17 PM
derFunkenstein derFunkenstein is offline
So I do have a question about iLok assets - do they become yearly things and expire somehow? Will I eventually have to "Log in" as well as have an iLok? I fear for my future.
Old 11-20-2014, 02:20 PM
Benoni's Avatar
No. Even if you choose NOT to continue your support plan after it expires, you WILL still own your Pro Tools 11 license (or whatever version you have at that time)
You will not be able to upgrade it without getting back on a support plan, BUT you still own that license. For anyone on MP, LE, EX, who is serious about Pro Tools, you have nothing to lose by upgrading now.
Please take the time to read over the FAQ's
http://avid.force.com/pkb/articles/e...2014-Offer-FAQ
And you can watch me talk about this if you want, though I basically say the exact same thing I just wrote.
Q. Will my Pro Tools license expire at the end of the one-year support period?
A. No, you can continue to use Pro Tools after your upgrade/support period expires. However, if you want to continue receiving upgrades, you will need to renew your upgrade/support plan. Customers will have through the end of 2015 to get on an upgrade/support plan.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 11-20-2014, 02:27 PM
Benoni's Avatar
Yes, you WILL need an iLok. All versions of Pro Tools from 9 and up require an iLok.
For Pro Tools 11 and forward, you will need an iLok v2. Many plugins require iLok anyway, so you will probably want one at some point anyway in order to use awesome plugins like Slate Virtual Mix Rack, or the Avid Pro Series Compressor and Limiter,
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 11-20-2014, 02:47 PM
sw rec sw rec is online now
I-lok TWO, to be exact. It won't work on an original I-lok.
Old 11-20-2014, 03:04 PM
Benoni's Avatar
Yes, I say that further down in the post
Originally Posted by Benoni View Post
[snip].....
The first gen iLok is shaped like a 'Key' while the version 2 iLok is rectangular
If you try placing a license that requires an iLok v2 on to an iLok v1, you will get this error.
So if you are doing the upgrade and do not already have an iLok v2, be sure you purchase the v2 and not the older v1 key style.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
FS: Pro Tools LE to Pro Tools 10 Upgrade Activation Card (+PT11 upgrade) bonwild Buy & Sell 0 06-17-2013 11:27 AM
free upgrade to pro tools 10 from Pro Tools 9.0 Crossgrade from LE Student Rikki Andersen Pro Tools 10 4 06-23-2012 02:57 PM
Pro Tools 10 Student Version- To upgrade, or not to upgrade? KFPCalvin Windows 4 04-12-2012 08:37 AM
Q: If I recently purchased a Pro Tools LE software upgrade—how do I obtain Pro Tools dmm Pro Tools 9 0 11-12-2010 10:14 AM
Upgrade to Pro Tools 8 (with upgrade dvd) asking for Auth code? (HELP) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-12-2010 01:40 PM
