G4/450 compatibility
Following Haze's path, can someone tell when tests concerning compatibility with sawtooth mother boards and especially 450 mhz machines will be completed ?
Does Digi 001 will, for example, take full advantage of the Velocity engine on such machines? Thanks for your answers and for this very informative forum. fiil. |
Re: G4/450 compatibility
I'm running 5.0LE with Digi001 on a G4/450
and having no problems so far. As far as I know (and heard at the demo), 5.0LE does NOT currently support the optimization of the Vel Engine, but will in the next version released. KW |
KW,
Are you using an internal or external hard drive with your G4? I'm trying to determine if I can go the route of a high capacity internal drive (either the one shipped with the system or a second drive I would add later). Thanks, Paul |
Hi again and thanks for the infos.
I think I will stick with the internal 20 GB ATA HD since I read somewhere in this forum that it seems to work fine. What you say? fiil. |
Sorry,
didn't notice the question wasn't for me. May help anyway. Ciao. fiil. |
Paul, go with an internal. Nice and neat.
I bought an IBM Deskstar 37.5 Gig drive for $510 from Promax. I use it mostly for video files and sometimes audio. The internal 27 gig drive that came with my G4/450 is completely up to the task and I've had no problems. That will work too. Good luck. KW |
I just added a western digital 27.3GB to my 450 im preparation for my 001 system. I got it for $244. Good to hear about success with the G4 450. Are you running OS 9 or 8.6? Has anyone seen 128 MB SDRAM for less than $200?
[This message has been edited by TonyWatkins (edited 11-12-99).] |
Using 8.6. I haven't seen much of a reason
to upgrade to 9.0 and have heard of some slowdowns. 8.6 is very stable, so...I'll wait. KW |
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade | benosullivan | Pro Tools 9 | 2 | 11-17-2010 11:05 AM |
V9 Compatibility | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-16-2010 04:51 PM |
Mac OSX Compatibility | Keniko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-24-2007 09:33 AM |
UAD-1 and PT7 Compatibility | M15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-08-2005 11:19 PM |
PCI-X Compatibility | kcurry | Pro Tools TDM Systems (Mac) | 6 | 07-14-2003 05:45 AM |
