Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 01-01-2013, 03:00 PM
BearJamStudios BearJamStudios is offline
Angry System 5 MC/XMON can't turn off MUTE... HELP!
Hello all,
For some reason, my "mute" led is lit on my XMON, but the "cut" button won't turn it on or off. I've tried all sorts of things. Anyone have any ideas? I can't hear anything from the speakers or headphones. VERT frustration.
Thanks
Mac 2x2.93 GHz Quad-Core Intel Xenon
32 GB 1066 MHz DDR3
Protools HDX
Logic Pro
Euphonix System 5 MC
UAD-2 OCTO ULTIMATE
Komplete 8 Ultimate
Ivory
LASS
Lots of other cool stuff.
Now all I need is to learn how to work it all!
Old 01-08-2013, 08:49 AM
H.G. Hollans's Avatar
H.G. Hollans H.G. Hollans is offline
Default Re: System 5 MC/XMON can't turn off MUTE... HELP!
I just want to be sure we got this issue resolved? I saw some emails the same day this was posted, and just want to confirm that this is the same person?
Thanks!
H.G.
Old 01-08-2013, 03:43 PM
Originally Posted by H.G. Hollans View Post
Thanks!
H.G.
I was contacted by someone at AVID who was VERY knowledgable and extremely helpful. He told me in 30 seconds what I had spent DAYS on here trying to find out. If that is the e-mail you are talking about...then yes, he solved that problem. Now if I could get him to fix ALL my ProTools problems what a wonderful day that would be!
Thank you for following up on this.
32 GB 1066 MHz DDR3
Protools HDX
Logic Pro
UAD-2 OCTO ULTIMATE
Komplete 8 Ultimate
Ivory
LASS
Old 03-05-2014, 02:36 AM
Roll Roll is offline
And what was the problem ?
thanks a lot !
Roland
Old 03-05-2014, 04:14 AM
thanks a lot !
Roland
Here is the response I got from AVID, and it worked.
"Hello Frank, If the red mute button is on that usually means the XMON has lost communication with the midi interface and the XMON software. If you are using the XMON software with a MAC, right click on the XMON icon in the tray and make sure the XMON is looking at the correct midi device port. Typically this is the M-Audio uno usb to midi or similar device. Once you right click on the XMON icon that device should be in the list of midi devices to choose from. This should then allow the XMON to talk to the MC and the mute light go out."
32 GB 1066 MHz DDR3
Protools HDX
Logic Pro
UAD-2 OCTO ULTIMATE
Komplete 8 Ultimate
Ivory
LASS
System 5 MC with XMON thezodiac System 5 5 12-27-2014 01:08 PM
System 5MC and XMON Talkback Mic Help Bear Jam System 5 6 11-30-2012 10:15 AM
Is it possible to use an AVIOM system with Xmon/D-Command????? HumDrumPrune2 ICON & C|24 1 03-29-2009 05:44 AM
002 RACK WILL NOT TURN ON - Red mute light silentknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-23-2005 11:45 PM
Faders turn the Mute on and Off JROB6716 MIDI 0 04-15-2001 01:16 PM
