Old 03-30-2012, 06:24 PM
2hip2b4real 2hip2b4real is offline
Default I/O Problems
I can't seem to link up to my Audio Files. My volume controls are grayed out on my mix window. Here are a few screen shots that may help in showing what is happening. I would appreciate your input.
http://i183.photobucket.com/albums/x...0at81246PM.jpg
http://i183.photobucket.com/albums/x...0at80522PM.jpg
http://i183.photobucket.com/albums/x...0at80549PM.jpg
I notice on the output screen shot the there is something missing that's on the input screenshot.
Old 03-30-2012, 09:19 PM
PD-John PD-John is offline
Default Re: I/O Problems
Have you got the correct Playback Engine selected? That message usually shows up when it has switched to something else (often the computer inputs).
Old 03-31-2012, 10:21 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
I agree with PD. Do you have the wrong interface selected? When you start up PT hold down the "N" key. A pop window will come up where you can select your interface.
Old 03-31-2012, 11:22 AM
The correct Playback Engine is selected. I should mention that this problem comes and goes.
Old 03-31-2012, 12:00 PM
KingFish KingFish is offline
Have you deleted all paths from all 3 tabs on your i/o, then on each tab, select "Default" -
This should redo your Hardware i/o, to whatever hardware is attached, recognized, and operating.
if it doesn't - you may need to find the drivers (If you're on ProTools 9) for your Interface, and reInstal them.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 03-31-2012, 01:34 PM
+1 Default
Old 03-31-2012, 02:17 PM
I will try that. Stupid question. How do I delete the tabs. This is what it looks like now and it's working.
http://i183.photobucket.com/albums/x...1at41048PM.jpg
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
Computer Problems vs Pro Tools Problems mudlake slim Pro Tools M-Powered (Win) 1 07-14-2006 08:09 PM
Rewinding Problems, Cutting & Pasting Problems Nikki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-22-2005 01:19 PM
Problems, Problems, Problems all day long... Jperkins Pro Tools TDM Systems (Mac) 5 05-12-2005 07:58 AM
PC Probe problems. Any overheatingg problems with Digi 001 Ajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-03-2002 05:30 PM
