Old 09-21-2009, 08:31 AM
neeel neeel is offline
Default hard drive enclosure
Hi all
I think this enclosure (link below) with a 7200 SATA seagate barracuda disk inserted will be pro tools qualified but can I get a second opinion or two?
http://atlastsolutions.com/shop/prod...roducts_id=556
neeel
MBOX MINI PTLE 8.0.3
MAC OSX Snow Leopard
Mac Mini 1.5Ghz Intel
2 Gig RAM
Old 09-21-2009, 08:38 AM
Default Re: hard drive enclosure
It looks good on paper
Old 09-22-2009, 12:47 AM
Thanks Albee1952
Anyone else with another opinion?
neeel
2 Gig RAM
Old 09-22-2009, 05:05 AM
BradLyons BradLyons is offline
They have a heat-sink, but where is the actual cooling system?
Thank you,
Brad Lyons
www.howavl.com
Old 09-22-2009, 09:25 AM
good point - drives get hot at the best of times - this could be a killer.
then again, it does look nice
neeel.
2 Gig RAM
Old 09-22-2009, 10:09 AM
neeel.
"I'd like excessive heat for $500, please"
"WHAT IS, THE #1 REASON THAT HARD DRIVES CRASH AND BURN FOR AUDIO AND VIDEO"??
Seriously---that is a huge factor, and IS the #1 contributor to why drives just lock up. Imagine if you're running a marathon in 115-degree weather in the beating sun down on you while it's 100% humidty. YOUR BODY WILL PASS OUT......some will be sooner than others, some longer than others. But eventually, it is going to happen. Read my article here:
http://www.theaudioprofessional.com/...ph_Drives.html
Thank you,
Brad Lyons
www.howavl.com
Old 09-22-2009, 11:44 AM
getz76 getz76 is offline
I don't completely agree with Brad's article. Just to add a different perspective...
Modern drives are much better at dissipating heat, even the high performance models. Your average 7,200rpm hard drive (2.5" or 3.5") will operate up to 60C without issue. In general, your 2.5" drive will operate cooler. In a properly designed passive case (like G-Tech's for example), even pushing it hard in a room with a reasonable ambient temperature (below 26C), you shouldn't get near 60C. You likely hover around 50C, actually.
My main issue with the Glyph drives is the fact they have the power supply in the case. I know they use this as a selling point, but the main problem with that is the heat that is generated by placing it there REQUIRES an active cooling solution.
The nice thing about using 2.5" drives is the handling robustness. Your average 2.5" drive will handle over 300G's without breaking, while your average 3.5" drive will handle about 30G's. Meaning if you transport your drive around at all, and you knock your backpack or sling over while jamming a sandwich in your face, the 2.5" drives will be more likely to survive. They are not bullet proof, but they're designed to be mobile.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 09-22-2009, 01:54 PM
Tritonemusic Tritonemusic is offline
I've worked in studios for the past three decades. The only drives I've personally seen fail are Glyph drives. THREE of them (three different occasions; three different studios). I've NEVER seen another brand die while working in the studio.
I'm just sayin'...that is my real-world experience. Your mileage may vary.
Don't believe the hype.
• Pro Tools LE 8.0.4cs2, Mbox 2 Pro • OS 10.6.5, Mac Pro 2 x 2.8 GHz Quad-Core Intel, 8 GB RAM • 7200 RPM System Drive, 10,000 RPM Audio Drive, 10,000 RPM BFD2 Drive
Old 09-22-2009, 02:12 PM
There were a pile of non-working LaCie drives at the last studio I performed in. It was their reminder to not buy LaCie drives anymore. :)
Old 09-22-2009, 03:10 PM
How long ago was this? Do you remember the model?
Thank you,
Brad Lyons
www.howavl.com
What external hard drive enclosure(s) do you use? GordonFreeman Storage Subsystems 27 05-15-2010 03:35 PM
External Hard Drive Enclosure Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2008 02:54 PM
External Hard Drive Enclosure jjhuntfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 11-15-2006 02:02 PM
Which Hard Drive for External Enclosure? acstctws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-22-2006 08:35 AM
Firewire enclosure for hard drive? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-20-2004 04:40 PM
