Opening session too slow
Powerbook G4 1.67 Ghz
2 gb Ram Mbox mini Osx 10.4.6 PT 7.1 Hi, here is a weird issue, I had everything working fine, and I have this 5 minutes song session with a lot of plugins. What is happening is that when I open the session it takes too much time loading the session, especially when is loading "building mix window" and all that, when finally loads the session everything is too slow. I have no idea about what is happening, but when is "building mix window" if I disconnect the usb cable, it loads everything smoothly, obviously when it loads the session appears a message that the mbox is not connected, so I don't know if is a hardware issue or not, because it was everything fine, the only change in the system was that i installed Finale, I upgrade to Pt 7.4 but the same happens. Thanks |
Re: Opening session too slow
Have you tried trashing preferences and databases yet? If not, please start there - info in the General Troubleshooting thread....
yes, I've tried
Slow startup / Slow opening sessions | MrSoliman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-21-2018 12:45 AM |
VERY SLOW opening sessions in the new HD8.0.1 | Shefi Yishai | Pro Tools TDM Systems (Mac) | 13 | 09-23-2009 01:22 PM |
Slow backups/re-analyzing audio after opening a 7.4 session on 8 | ampnerd | Pro Tools TDM Systems (Mac) | 5 | 04-13-2009 07:04 AM |
PT 7.4.2 + Leopard 10.5.4 SUPER SLOW OPENING SESSION | Paul B. | Pro Tools TDM Systems (Mac) | 5 | 08-01-2008 11:58 AM |
Waveshell V6 slow opening PT LE? | leftright_mastering | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-22-2008 11:58 PM |
