Old 03-12-2009, 10:21 PM
d00m1001 d00m1001 is offline
Default Applying Instrument Tracks to Reg. Audio Tracks
Hi, this might be a weird question but, one of my plugins (Effectrix amoung others) can only be accessed when I'm on an instrument track yet, the plugin really isn't a virutal instrument, it's more like an effect that should be able to be applied to audio that I record.
Is there any way to re classify the plugin to show up under the inserts on an Audio track?
Also, is there anyway to make it so that the effect only lasts for a certain amount of time before stopping (and maybe coming back in later)?
Thanks! Here's some general info of what I'm using
Pro Tools LE 8
Mac OSX 10.5
MBox Mini
Thanks in advance.
Old 03-13-2009, 03:57 AM
The Dougfather The Dougfather is offline
Default Re: Applying Instrument Tracks to Reg. Audio Tracks
Are you it's just not a stereo plugin, my Korg plugs are like this, no mono.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 03-13-2009, 04:41 AM
Phil Ogden Phil Ogden is offline
What about instantiating it on an Auxiliary track? Then you could buss the audio track output and automate the plug-in bypass so that the effect is only applied where required.
http://www.myspace.com/philogg
Old 03-13-2009, 05:54 AM
Sardi Sardi is online now
Effectrix works fine on an Audio track. That's what it's designed for. I use it all the time to 'Glitch' things on Audio tracks.
I'm pretty sure it works as a stereo insert only so make sure you're not trying to insert it on a Mono track. That would explain why it's not showing up in your list of plugs.
Old 03-13-2009, 05:11 PM
This is probably my best bet. thanks! How do you automate bypassing though?
Old 03-13-2009, 07:19 PM
Hmmm.... did you read my post above?
It DOES work on an audio track. It's NOT an instrument plugin.
If it's not working, something is set wrong.
Check the pic:
http://img27.imageshack.us/img27/8362/effectrix.jpg
Old 03-13-2009, 08:55 PM
No, I got it to work, just using Phil's technique. I'll go ahead and try it on a stereo track though just to make sure all is well.
EDIT: It works. thanks!
Recording with instrument tracks and audio tracks Shan B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-01-2011 02:22 PM
No audio on Instrument Tracks DjTremor Windows 24 03-12-2011 05:16 PM
Instrument or audio tracks kasso Tips & Tricks 6 01-27-2010 04:58 PM
MIDI Tracks Versus Instrument Tracks. VERY Confused. Rick540 MIDI 8 12-04-2008 11:04 AM
Instrument tracks VS Aux tracks+MIDI tracks mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-03-2006 04:08 PM
