Probable bug in "notes" view on midi channel with smart tool
I would call this a bug, maybe others have encountered it, or perhaps it is a design feature(if it is I don't like it).
When in "notes" view on a midi channel and the smart tool is selected, you can only grab and move a note(with the hand) when that note is contained within the lower half of the display. I know this did not always work that way and it makes it quite difficult to edit midi(for me at least). Is anyone else having this problem? Thanks! |
Re: Probable bug in "notes" view on midi channel with smart tool
Which version of protools? I am having no problems like this in either 7.4 or 8. If you are in PT8, try the midi edit window(new feature) and see if it happens there.
PT8... I haven't experienced this.
Oh, sorry I didn't say that I'm on PT8, oops. The midi edit window is working fine, it's just when I'm trying to edit midi in the regular edit window. I'm on a PC with Vista Ultimate btw. Thanks for checking it out.
I was just messing around with it some more and discovered that it only happens when the grabber is set to "separation." Maybe I'm wrong, but if someone has a chance on 7.4 could you try to move a note in the upper half of a midi track whle the grabber is set to separation? It looks like maybe it isn't a bug, just a different way to work. I usually leave the grabber in separation, I guess I'll just get used to this-no big deal.
I think you are correct that they changed the tool action slightly. I posted about a little confusion myself just days ago. Like you, I am resigned to just relearn as there are a few things that have changed subtly. Plus I am getting used to the Mac shortcuts on a new Mac Pro and that gets confusing too.
There've been a couple other little changes that I've had to get used to in v8.0 as well. For example, in velocity view, if you are using the Smart too, you used to be able to hit Ctrl (I think) to toggle the grabber to the trimmer tool, no more. Not really a show stopper, there are plenty of work-arounds, I've just had to get used to not having a workflow trick I've been using since version 5.0. Old habits die hard...
Shortcut for "view channel strip" command? | Zakazastar | Tips & Tricks | 22 | 08-25-2014 10:13 AM |
"Smart" tool stuck. | bongo_x | macOS | 2 | 07-28-2012 06:49 AM |
If the "smart tool" was really smart... <tongue in cheek> | KingTor | Post - Surround - Video | 10 | 03-02-2010 09:47 AM |
HELP! smart tool eraser to delete MIDI notes WON'T WORK! | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-28-2008 09:05 AM |
"Smart tool" not working in shuffle mode | AAronc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-04-2002 06:53 AM |
