Old 01-08-2009, 01:35 PM
esamaxe1 esamaxe1 is offline
Default Tough Tempo Question
In your tempo ruler area (green). After you've set a tempo map or there is one already there, When I select a region and use tools such as the trim tool to lower that particular time area region in the song, it stretches and changes the tempo of all proceeding time regions/tempos. This is annoying, I spoke to a PT tech support guy, but said there are ways to do it so other regions don't move but too detailed and to come here. This could be extremely helpful in tweeking your tempo maps to be perfect and infinite possibilities from there. ANY KNOWLEDGE PLEASE?
Old 01-08-2009, 02:16 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Default Re: Tough Tempo Question
right here is where you lose me. I'm not sure what you are trying to describe? Are you saying you use the trim tool to trim an audio region's front or end so the audio region is shorter and by doing so, the tempo changes?
Not sure if we are calling everything by the same name. In protools, "regions" are what the actual audio clips is called. If you select a section of time, for example from bar 1 through bar 3, that is normally called "a selection" in protools and you can have audio regions(clips) within it. Usually the only things that go "lower" or "higher" in protools is volume, and you can adjust volume using the trim tool...
To me, what you just described is selecting a piece of audio on an individual track, and then you dropped the volume and in doing so, changed the tempos of all the audio around that piece of audio?
So... looking at what you are saying... you might be trying to select a section within the tempo timeline and have just that selection be a different tempo? But if that were the case, it wouldn't change the tempo of anything around the selection... so again, I'm not exactly sure what it is you are describing...
Sorry about that, just try to explain a little further what it is you are trying to do. Maybe give a couple step by step things you are doing so we can help you a little better.
Tough.... Dorian Green 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-05-2010 11:01 AM
Tough Tempo Question esamaxe1 Pro Tools TDM Systems (Mac) 1 01-06-2009 12:40 PM
This is a tough one! PhilHall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-05-2006 10:47 PM
her's a tough one HELP mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-29-2004 10:59 PM
888 I/O Tough Times Don Henry General Discussion 0 05-25-1999 03:28 AM
