Old 01-07-2009, 08:13 AM
DrFord's Avatar
DrFord DrFord is offline
Default Fader Meter Behavior in PT8 and Fader Weights
Can someone explain to me a bit about setting the weight of the faders meters? I understand that it has to do with voltage (as once explained to me by O.G. Killa) but I don't think I have the proper equipment to calibrate correctly, and am not sure what the exact difference would be between
-18dbs & -16dbs and how that would effect the behavior of the fader Or the look of the meter?
Are those my only 2 options as well -18 and -16? It seems like a free text field.
Thanks
D
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 01-07-2009, 11:31 AM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Default Re: Fader Meter Behavior in PT8 and Fader Weights
Thanks
D
I haven't upgraded to PT8 yet, but I can't find any mention of this feature in any of the PT8 documentation... where are you seeing this?
Old 01-07-2009, 01:01 PM
JFreak's Avatar
JFreak JFreak is offline
It's got nothing to do with voltage as most digital meters measure relative to "digital full scale"...
Janne
Old 01-07-2009, 01:52 PM
O.G. Killa's Avatar
Uh oh... here we go again! LOL
Your "calibration reference level" on a digital meter is in reference to an analog voltage measured at the output of your interface. That's what Dr. Ford was alluding to. There was a big, heated discussion/debate about this over in the PTHD tips forum.
There is also some confusion about it sometimes. For example, -15dBfs on a 002 will have the exact same analog output volume as a PTHD 192 IO (Using Trim A) at -18dBfs or a 192 IO (Using Trim B) at -20dBfs.
Since +4dBu is used as the reference voltage level for most professional audio equipment, with a volt meter connected to the outputs of your interface a sine wave at a certain dBfs level should create an output voltage of 1.228 Volts (RMS). That Certain dBfs level on a 192 IO is -18dBfs using trim A, -20dBfs using trim B and I believe it's -15dBfs in a 002/003 (Maybe -14dBfs?). This way... if you are using a mixing console who's line inputs are calibrated for +4dBu = 0 VU, when a signal with a voltage of 1.228 Volts (RMS) comes into the mixer's line input the VU meter will read "0 VU". Then say you send your mix to a 1/2" analog tape machine which is also calibrated for +4dBu=0VU, when your mix bus meters are saying 0 VU, your tape machine meters will be saying 0 VU. And if you simultaneously split your mix to a DAT or CD recorder that is calibrated for +4dBu= [Some number] dBfs (for this example we'll say -18dBfs), when your mix bus on the console says 0VU and the meter on the tape machine says 0VU the meter on the CD player will read -18. And if your PTHD system is using it's factory Calibration of -18dBfs as well... the chain would look like this...
PT -18dBFS (1.228volts) = 0 VU (1.228 volts) on console channel = 0VU (1.228 volts) on Console MixBus = 0VU (1.228 volts) on tape machine = -18dBfs (1.228 volts) in the CD recorder.
The term "weight" of a fader's meters is something I have not heard of before... so I'm not sure how it relates to calibration and reference levels.
Old 01-08-2009, 02:23 PM
DrFord's Avatar
Thanks OG, I will check where exactly it is and post tonight.
D
DRFord
Master fader and meter readings jasonthurley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-24-2010 09:48 PM
mixer meter not responding to fader hoss33 Tips & Tricks 4 11-23-2009 10:21 PM
viewing numerican master fader meter? CrAkD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-15-2008 05:45 PM
Strange 5.1 Master Fader Behavior When Bnc to Disk kcupper Post - Surround - Video 3 03-02-2006 07:10 PM
Level meter on Multichannel Master Fader Redbeard Post - Surround - Video 4 07-24-2003 05:34 AM
