Pro Tools HD without a mixer or control surface. Ways to connect to your monitors
I got a PT HD 2 with a 192 i/o. I have no mixer as I only really record 1-4 inputs at a time. I need to buy something to be able to control the volume of the speakers and headphones.
I have checked Mackie's Big Knob. But is this relly good? Another possibility is to wait for the replacement of the Command|8 (when?) and use it as a controller and monitor control. What does people without a mixer/controller use? |
Re: Pro Tools HD without a mixer or control surface. Ways to connect to your monitors
I used a Yamaha 01V with a AES/EBU card as my monitor controller and DA for a few years. Then I bought a Benchmark DAC1 with DA-conversion + stepped level control in the front. A big step up soundwise. Now I have a D-Command, but still use the Benchmark as my DAC.
I use the m906 from Grace Design, it is 5.1 with a remote controller and it sounds fantastic! They also have a cheaper stereo version m904 without a remote controller. I also have a ProControl but I do not use the analog monitoring section, the m906 is much much better
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
Check out:
http://cranesong.com/AVOCET.html Another solution to consider. I've been extremely happy with this unit. |
I've been extremely pleased with the Crane Song Avocet, which I've had for a couple of years. It has great routing for inputs (3 digital pairs plus 3 analog pairs) & outputs (3 pairs), plus integrated talkback & phones control. Also, their tech support has been excellent for the few questions I've had. Highly recommended!!
http://cranesong.com/AVOCET.html Warmest Regards, Brian |
Another Big Yes For Avocet
First and most important of all very transparent Every component under the hood is top quality Lots of in, out, talkback and phones options Excellent tech support Last but not least (unlike most others) its an aesthetically pleasing piece of audio gear |
Thank you all! That is great!
People who uses/tried the AVOCET and Grace Design controllers, what do you have to say about the Big Knob from Mackie? |
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
Before I went with the Avocet, I had been listening through a Mackie HUI, and becoming increasingly frustrated with what I WASN'T hearing. I asked around a LOT about different controllers, and I was trying to spend as little money as possible. Everyone who'd heard it said the Big Knob was "okay", but essentially the same as listening through a small Mackie mixer. That's not a bad solution for occasional use, but not great if you work long days, and definitely nowhere near as good as a professional unit like the Avocet.
You get what you pay for, and I've never regretted putting out the extra money to get a MUCH better piece of gear. It was like I'd bought new monitors, with a huge improvement in sonic detail, depth & soundscape. Panning, reverb tails, low-end clarity... all became much more defined. HTH. Warmest Regards, Brian |
is it possible to have 002 mixer as control surface only? | internationalnova | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-11-2012 08:50 AM |
trying to connect mid USB control surface... | cinetj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-07-2010 01:38 PM |
analog mixer + control surface = digital mixer? | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 10-11-2006 05:12 AM |
Best Mixer/Control Surface for 001 | ian benn | General Discussion | 6 | 01-31-2003 04:38 AM |
Control surface/mixer? | TRK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-03-2001 01:51 AM |
