Can\'t monitor midi controlled sounds
Looking for some quick help...
Track 1: Stereo Audio, Input: 1-2, Output 1-2, Sampletank inserted Track 2: Midi (rec enabled), Input: All, Output Sampletank Ch1 I can only hear the midi controlled sounds upon playback after recording. Subsequently, I can monitor the "mini keys" when played on the Sampletank interface, but I cannot record the mini keys.. What do I have set up incorrectly? Thanks in adavnce, J |
Re: Can\'t monitor midi controlled sounds
Two points, SampleTank requires MIDI Input, either from a MIDI Controller or programmed free hand (Pro Tools Pencil tool) and secondly, SampleTank should be instantiated on an AUX track.
filosofem
Aaron Mulqueen - 001 HD Native |
Thanks,
I actually have set up "track 1" as an AUX track with the same result. I'm assuming Sampletank is getting MIDI input from my controller as PT records the Sampletank sounds fine, I just can't monitor them until they are recorded.. Quote:
Is 'MIDI Thru' check? Pro Tools>Options. Is the MIDI track record armed?
filosofem
Assigning MIDI sounds to MIDI controller and playing sounds with MIDI | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-02-2009 12:52 PM |
Midi i/o controlled by other sequencers? | Glenn75 | MIDI | 1 | 11-05-2004 06:13 AM |
MIDI controlled GATE plugin | Judson | MIDI | 1 | 10-31-2004 07:57 AM |
Can Pro Tools be controlled by/respond to MMC (MIDI Machine Control)? | bwherry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-10-2003 07:17 AM |
midi controlled samples | blake eat world | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-14-2001 12:13 AM |
