Old 06-20-2007, 05:18 PM
JoeyBoomBox JoeyBoomBox is offline
Default 003 Macintosh Audio
I just hooked up my brand new 003 and it's daisy chained through an external hard drive. I want to switch the audio driver in the Apple System Preferences but it's not seeing the 003. Anyone know a way around this?
Old 06-21-2007, 03:42 AM
peppertree peppertree is offline
Default Re: 003 Macintosh Audio
I'm getting ITunes playing through the 003, but not system beeps, and not when Pro Tools is running. The Digi Core Audio driver runs when this runs. The Audio Midi Stup utility is used to configure it. Unfortunately S/PDIF mirroring STILL doesn't work as of 7.3.1cs3.
I don't have any other Firewire devices than the 003 hooked up. I might not daisy chain it...do you have two firewire ports on your machine?
`My name is Pro Tools HD, King of Kings:
Look on my works, ye mighty, and despair!'
Nothing beside remains. Round the decay
Of that colossal wreck, boundless and bare,
The lone and native DAWs stretch far away.
Old 06-21-2007, 11:02 AM
DigiTechSupt's Avatar
Most likely you need to install the Core Audio driver.
Avid Audio Tech Support
Support FAQ
Old 06-21-2007, 11:04 AM
If Pro Tools is running, it has exclusive use of the hardware - thus iTunes nor any other application will be able to use it.
System sounds cannot be routed through a Core Audio device - this is a limitation of the OS.
As for SPDIF mirroring - are you trying to use this in Pro Tools or the Core Audio driver?
Support FAQ
Old 06-21-2007, 07:41 PM
Via Core Audio. This is one of your known issues that your elves should be whittling away on.
Old 06-21-2007, 10:41 PM
Goobs's Avatar
Goobs Goobs is offline
Interestingly, I have no problem getting the system sounds to go through an MBox2 Pro, yet if I have any of the other LE interfaces attached (Mbox/Mbox2/002/003) the option is grayed out.
Conversely, all LE interfaces seem to show up in the Digi CoreAudio Manager *except* the MBox2 Pro. Any hypotheses on why the MBox2 Pro seems to be such an enigma in this regard?
Curious,
Jeff
iMac (Retina 5K, 27-inch, Late 2015), 4.0 GHz Intel Core i7, 32 GB 1867 MHz DDR3, 500 GB Flash Storage SSD, macOS 10.14.6
Pro Tools|Ultimate 2020.5, Logic Pro 10.5, Nuendo 10.3, Cubase Pro 10.5, Reason 11.3, Live 10.1, Digital Performer 10.11, Studio One 5, Waveform 11.0.26, Reaper 6.08, WaveLab Pro 10.0.40
Waves Horizon/Diamond 11.0.58, Melodyne 5, iZotope Post Production Suite 4, iZotope Music Production Suite 3, Soundtoys 5.3
Apogee Quartet, Eleven Rack, 003, Command|8, OWC Thunderbolt 2 Dual-Drive Dock, OWC Mercury Electra 480 GB 6G SSD, OWC Mercury Elite Pro 250 GB 7200 RPM HDD
Macintosh HD is not an audio playback? danefoltin Pro Tools M-Powered (Mac) 2 05-04-2008 07:53 AM
"Macintosh HD" Cannot be designated as an audio... PJJames 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-26-2006 04:42 AM
Macintosh PT Free and MacOS USB Audio N9YTY Digidesign Hardware & Software 33 04-26-2001 07:38 PM
Macintosh USB Audio In N9YTY Pro Tools TDM Systems (Mac) 3 02-13-2001 08:21 AM
Macintosh USB Audio Input N9YTY General Discussion 1 02-01-2001 09:40 PM
