Old 06-17-2005, 08:55 PM
Bogner Bogner is offline
Default Master Fader 6.7 Master Fader issues
Has anyone had a problem with the master fader not working after adding a plug-in in 6.7 LE. I have added the EQ III plug-in in a session and there is no master fader output, there doesn't appear to be any signal going to the master fader after the plug is added, all other faders appear to work normally. I save the session, close Pro Tools and open the session and everything work properly. Are there any known issues with this?
Thanks Jim
Old 06-18-2005, 09:35 PM
Default Re: Master Fader 6.7 Master Fader issues
Interesting for sure. I don't have a real answer. Maybe this is due to the fact that EQIII was released for 6.9 and it only "sort of" works with earlier versions? In any case, my recommendation is to save master EQ for seperate mastering whether you use protools or another program. I go back and forth between PT and WaveLab and find both work very well. After using master faders on a few projects, I have stopped using them completely now. If I need a fade, I do it in my mastering session where I also trim the start and end of the final mix. Since I don't consider myself a mastering engineer, I tend to keep it simple and usually only put a little Waves L2. I rarely use master EQ but like anything else, YMMV.
Old 06-19-2005, 12:07 AM
Are you in Low Latency Mode?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-19-2005, 07:23 AM
Rail, I have only had this problem when mixing and not in low latency mode.
Jim
Old 06-19-2005, 07:42 AM
The subject is a little misleading, I'm speaking of the master fader I add in a session that is not working after adding the EQ III plug. Just to clarify, I can add EQ III to any track and it causes this problem, I don't add it to the master fader. If there is a program called Master EQ I'm not familiar with it, I leave mastering to the mastering guys. I have not moved to 6.9 yet, 6.7 has been working so well I have not had a need too. I guess I'll make the move soon between projects.
Jim
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
major issues with master fader plugins and PT satchvai Tips & Tricks 4 04-05-2006 06:57 PM
weird master fader issues... Ken P Pro Tools TDM Systems (Win) 5 01-29-2005 08:51 AM
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? Ricky Cobble Pro Tools TDM Systems (Mac) 5 05-05-2003 04:47 AM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
