Old 11-03-2012, 02:39 PM
MARVINBASS's Avatar
MARVINBASS MARVINBASS is offline
Default Re: -9129 error and HDX
Originally Posted by SHIRK View Post
Sometimes I get this error when I go over to my patchbay and touch it with a patch cable. Seriously. I don't see any visible elector-static arching or whatever you call that. ...I don't hear or feel any either. I have Redco 96 pt TT patchbays with dsubs going too and from all my gear.
Weird.
Grounding Issue?
My System is:
Mac Pro 3.2GHz 6 Core
32GB RAM
1- HDX
1 - Apogee Symphony Mk2 8x8
1 - HD 16x16 Interface
MOTU MTP/AV
Second System
Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2
32GB RAM
1 - HDX
1 - Avid Thunderbolt 3 Expansion Chassis
1 - HD 8X8 Interface
MARVINBASS Digital Audio, LLC
Ex PT Beta Tester
Woodland Hills, CA.
Old 11-03-2012, 06:44 PM
SHIRK SHIRK is offline
Originally Posted by MARVINBASS View Post
Grounding Issue?
That's what I was wondering as well. Never had this problem when the 192 i/0 was in the rack in place of the Avid i/o 16x16.
I'm going to check the grounding switches on the RedCo patchbays and see if something got changed....somehow?
SHIRK
www.shirkmusic.com
www.hearya.com
MacPro 12core 3.46Ghz (5,1)
OSX v10.14
48GB RAM
1x HDX
2x HD i/o 16x16, 1x Digi192 8in/16out
Pro Tools Ultimate 2021 on HDX
Old 11-04-2012, 11:14 AM
MARVINBASS's Avatar
That would be a good place to start.
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 12-12-2012, 12:15 PM
KingFish KingFish is offline
Do you have to boot / run in safe Mode every time you start up to use HDX ?
My HDX is running ok here on my 12 core Westmere, but I have a friend that just bought an HDX card, put it on his Nehelam 8 Core, and he can't get through 5 minutes at a buffer of 1024 with 6 tracks of audio without the CPU conflict error.
I'm about to go over there and help him troubleshoot.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 12-12-2012, 12:21 PM
MARVINBASS's Avatar
Originally Posted by KingFish View Post
So... what is "Safe Mode"? how does that cripple the machine? do you have to boot / run in safe Mode every time you start up to use HDX ?
Have him put the processors down to 6. It's seems to help
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 12-12-2012, 12:39 PM
I'll do that.
It'll be a real drag if he has to run his machine in Safe Mode full time, I've read on Apples site all of the disabled functionality that could be a drag.
You other guys, your full time solution, is to always be running in Safe mode ?
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
Old 12-12-2012, 12:51 PM
MARVINBASS's Avatar
I'll do that.
No! You don't have to run it in Safe Mode. Just clock back the processors in Pro Tools to half of what the Mac is. This causes Pro Tools to not Multi-Thread.
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 12-24-2012, 04:40 PM
Gotta say, can't un an 8 Core Westmere set to 8 of 16 CPU's at 85% OR 99% with an HDX card, and use any 3rd party soft Synths, like Omnisphere, Alicia's Keys, or Massive without having to run a buffer of 512, or 1024 (Which make the latency impossible to play), and STILL even at those High buffers, spit up 9171 CPU and even 9073 (Can't get audio from disk" WITH the timeline cached...errors.
Not sure if they are related to these 9129 errors in this thread , but if I pull the card, the same session runs Natively, all day long at 128 Buffer. or with an HD Accel Card, no problems.
I've always had this problem with HDX - Not nearly as stable as HD Accel
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
Old 12-24-2012, 05:58 PM
MARVINBASS's Avatar
Hi KingFish, did you just update to PT 10.3.3?
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
9129 error whispermode Pro Tools TDM Systems (Win) 0 09-01-2009 03:31 AM
DAE error (-9129) need help!!!!!! Lil G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-14-2007 11:32 PM
Need Help With 6.4 LE (Error (-9129) ryankasdorf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-14-2005 09:36 AM
6.4 Error -9129, huh? BIg Mick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-05-2004 10:30 AM
Please Help !!!!!!! 9129 error brucegoose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-10-2002 04:20 PM
