A few questions regarding ram, processing etc
Ok first off forgive my ignorance and my being lazy for not thoroughly searching out these things before posting. You guys seem to answer things almost instantly which makes me even more lazy for looking up things.
Here are just a few questions. I have a mac G5 dual 2.5 with 3.5 G ram 1. How much ram is enough for PT 8 or when does it just simply not matter anymore. Should I just max out my machine or does PT only recognize up to a certain point. 2. I was always under the impression that PT only used one processor, This may just be from way back as I have been using it forever and that is just what i remember. if i can use both is it recommended, and how do I make this happen. 3. When opening my maxed out older sessions from 7.2. PT 8 opens the sessions fine but some of my plug ins are grayed out (not from Incompatibility) just from not enough power. Why would PT 7.2 be able to run all of them and PT 8 cannot. Thanx again for any info
www.nightskystudios.org |
Re: A few questions regarding ram, processing etc
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
Thanx alot for the info. It is appreciated.
I am running 3.5 g ram right now if Pt only utilizes 4 gb ram do you think the extra .5 is worth it?? I will set my cpu to max as well for the rtas. My plug ins are compatible for sure, all my plugs have been upgraded, as I mentioned before they just simply don't open in maxed out sessions. Its usually just a couple that don't pull up but when I open the same session in 7.2 they open fine. Does Pt 8 require more power to run? if so maybe this is why the plugs wont open?? Its happened on numerous sessions since the upgrade. On the ones that don't come up i make them rtas and not TDM. This is the only way they will work. Seems like I get less TDM plugs in PT 8 . On another note i was running a big session and PT told me i was out of Voices. i counted and seems like i was running a total of 84 voices but PT told me i was out and my setting was 96 voices. Again the same sessions pulls up fine in pt 7.2 with no voicing issues. any thoughts?
I am having very similar problems to what the original poster was alluding to. I will have to get to the Mac Pro I'm using and figure out if you've already solved my problem and I'll come back again.
The DUC saves my life so many times.
Mac Pro running OSX 10.5.6, using Pro Tools LE 7.4.2/Digi 003/Digi C24 w-DV Toolkit 2, a pair of Avalon 737 VT-737sp's, Great River MP-2NV, RME OctaMic II, pair of Mackie HR-824's, my best mics? a Neumann U87 and a Royer R-121 . . . best amps? Bogner Ecstasy 101B and a Bogner Uberschall-Revision Blue . . . All my drums are BFD2 triggered by Roland TD-20s kit, with live Zildjian cymbals, Korg Triton LE 88 with weighted keys . . . lots of other toys that make beautiful music . . . |
m/s processing | ballerina | Tips & Tricks | 0 | 08-22-2007 02:50 AM |
OK, here's one. DVD pre-processing... | Stuart P. | Post - Surround - Video | 5 | 08-25-2005 06:20 PM |
First time video post processing questions. | Rabidium | Post - Surround - Video | 8 | 06-03-2005 12:19 AM |
processing vox | dragnfli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-09-2003 01:16 PM |
Questions about audio fidelity after processing... | O.G. Killa | Pro Tools TDM Systems (Mac) | 0 | 04-29-2003 01:01 PM |
