Old 01-20-2019, 02:19 AM
Decosboss Decosboss is offline
Default Eleven Rack producing little to no signal through Behringer power amp
Hey,
New 11R owner, recently purchased a secondhand unit, had no issues with it, but only ever played through headphones until recently. Purchased a Behringer A500 power amp (https://static.bhphotovideo.com/lit_files/84866.pdf) to run through my Marshall MX212 cab (https://marshall.com/marshall-amps/p...212-and-mx212a).
My chain is as follows:
11R Out to Amp 2 > A500 Input 1 > A500 Bridged Mono Out (note: I have same issue in stereo mode) > Marshall MX212
All settings on the 11R seem correct, but maybe I'm missing something? When wired up as described above I get a very weak signal, and I start to get popping noises when I turn the channel volume of the A500 around 12 o'clock.
I can't think of any reason for this to occur, I've tried various alternative methods for troubleshooting, but with no success. If anyone could point me in the right direction, or tell me what (if anything) is faulty, that would be much appreciated!
Eleven Rack and Behringer FCB1010 The-Edge Eleven Rack 6 09-12-2017 09:59 AM
Behringer FCB1010 with Eleven Rack Kruegmeister Eleven Rack 11 12-13-2015 08:31 PM
Eleven Rack and Behringer BTR2000 Connection? arturocivit Eleven Rack 0 02-13-2014 04:15 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Behringer FCB1010 Uno Eprom Sysex File For The Eleven Rack Benoni Eleven Rack 3 06-04-2011 06:17 PM
