Old 02-14-2012, 12:06 PM
RandyPokeda RandyPokeda is offline
Default Mix Window too Small
Can I increase the size of the mix window so it fills the entire screen? Thanks in advance for anyhelp here.
Randy
Old 02-14-2012, 12:08 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Mix Window too Small
Randy
Yes, just drag from the bottom right corner. or hit the green button top left.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-14-2012, 12:10 PM
paulrgmusic paulrgmusic is offline
You should just be able to drag it out to whatever size you want. There are a couple of apps you can get which make the green button act as the fullscreen button on windows. One such app is called RightZoom I think. You don't need one of these apps but it makes it quicker to make a window full-screen.
2011 27" iMac
3.4 GHz i7
12GB RAM
500GB G-Drive Mini (FW audio drive)
Mac OS X 10.7.3 (Lion)
Pro Tools 10.0.1
Mbox 2 Pro (connected by FW)
Old 02-14-2012, 05:12 PM
Carl Lie Carl Lie is offline
When you have it full screen just hit command + to toggle back to the editor screen.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Small Video in BIG Window Jeffrey Talbot Post - Surround - Video 3 04-18-2012 09:00 AM
Small problem with the view of my Sends in Mix Window Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-14-2009 10:18 AM
Transport Window and Color Selection window lost cd_audio_mix Pro Tools TDM Systems (Mac) 6 11-26-2006 10:58 PM
Plugin window is too small Charles Schaefer Pro Tools TDM Systems (Mac) 0 03-25-2006 12:06 AM
Post window TOOO SMALL!!!!!!!!!!!!! *DELETED* where02190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-04-2003 07:08 PM
