Plug-ins not showing in plug-in window
I've just installed the Pulltec EQ bundle, and DINR. Both of the newly installed plug-ins are not showing in the plug in window within the mix window. What needs to be done to make the plug-ins usable?
Thanks for the help in advance, -nate |
Re: Plug-ins not showing in plug-in window
So when you launch PT, do you get a window that asks you to authorize the new plugs or did you already do that? Are they in the plug-ins folder?
What is your OS and PT version?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Pro tools launches as normal. It does not prompt for plug-in authorization. My copy of DINR and the Pulltech bundle have been authorized. I see the names of the plug-ins that I am trying to use quickly appear on the launch screen when I open pro tools, but when I get into a session they are not in the plug-in menu.
I am running Pro Tools LE 7.1.1. With an intel mac running 10.4.8 |
Is the version of DINR 7.1.1? I think that is the first version that works with Intel Macs. Pultec should also be at 7.1.1.
Plug-In Compatibility Make sure that all Plug-Ins are compatible with Pro Tools 7. -Open MacHD>Library>Application Support>Digidesign>Plug-Ins -Check the Version of each Plug-In You can check the version by selecting the plug-in and go to the "File" menu and choose 'Get Info', or hit Command-I and look at the version information under the 'General' Section -Digidesign Plug-Ins should be version 7.0 (Dynamics III version 6.9) or higher -Check with third party plug-in manufacturer's to confirm that the plug-in version you have is compatible with Pro Tools 7, and here: Pro Tools 7 Plug-In Compatibility Linked from the Pro Tools Plug-Ins section of the website: Pro Tools Plug-Ins
PTools Not Showing new files in track window after burning in plug-in | Hollow Body | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-27-2008 08:42 AM |
Some plug-ins not showing up | c-tone | Pro Tools TDM Systems (Mac) | 4 | 03-22-2008 02:50 PM |
AudioSuite Plug-ins not showing on track plug-ins | dappmasters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-23-2006 06:35 AM |
Fix for IK Plug-ins Not Showing Up in PT 6.x | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2004 06:03 PM |
Plug-ins not showing up in PT | Samhein | Pro Tools TDM Systems (Mac) | 2 | 10-23-2001 08:38 PM |
