Old 04-18-2001, 10:50 AM
CHRIS AIKEN CHRIS AIKEN is offline
Default Midi Patch Changing
I have an Lexicon MPX1 I'm using with PT 5.1 I've typed up a patch name list to change patches via a midi channel in PT's.However when I change the patch it changes to the appropriate patch but when I start playback on PT's it defaults back to patch one.And the really strange thing is that
the farther along I start playback the higher the patch number it defaults to.(If I play from 0 it defaults to patch 1 if I play from about 30 secs in it defaults to about patch 40).I also have a PCM 91 that works fine in this regard.
Thanks Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
MIDI patch changing from DAW sanjaydas7 Eleven Rack 10 02-16-2014 08:38 AM
Patch Name Changing Automatically on KorgKrma-HELP autopilot MIDI 0 03-19-2005 10:57 AM
Changing MIDI Patch Name Changes All Midi Tracks cheerio MIDI 2 10-31-2004 07:49 AM
Midi Patch keeps changing back to first.. Vinseph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-04-2003 09:13 AM
Changing Patch Names?? Mista Digga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2000 06:10 PM
